Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 08-03-2004, 04:47 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Re: Re: Re: Re: turbo fabrication
Originally Posted by GTmike400
Usually the penetration wont matter is much when your just doing a fillet weld (and its not for structural use), but still, welding two different thicknesses is the biggest pain in the ass. Especially welding .063 to .25, thats tricky ass hell.
Penetration really matters when you're welding stainless that is going to be heated up red hot, and then cool down to ambient air temperature every time you drive the car.
You want good penetration with a slightly convex weld profile, it gives it a little more reinforcement, and a little bit more room to stretch as it expainds.
Integra06, sounds like you've got a good way in to a good trade, and a good plan. If you can that much practical experience, you should have no problems getting apprenticed.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 08-03-2004, 09:34 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Re: Re: Re: Re: turbo fabrication
When welding 18-8 you can get great penetration by turning down the IPM of the wire, and creating more of a fission process for MIG. I forgot turbo shit got that hot...oops. We dont use many turbos on hot rods.
-Mike
Old 08-04-2004, 03:34 AM
Cbass's Avatar
Re: Re: Re: Re: Re: Re: turbo fabrication
Actually, turning up your wire speed tightens the arc gap to a point, and makes for a slightly hotter weld with deeper penetration. Turning down your wire speed too much can lead to big problems.
What are you welding that requires 18 to 8 gauge? Reinforcement for unibodies?
Old 08-04-2004, 11:36 AM
mike@af's Avatar
Re: Re: Re: Re: Re: Re: Re: turbo fabrication
18-8 is another name for stainless.
-Mike
Old 08-04-2004, 02:44 PM
Cbass's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: turbo fabrication
That would explain why I didn't recognize the term I don't get to weld much stainless, mostly all mild steel fab. What I have done is all 1/2, and that was with stick.
Old 08-04-2004, 03:56 PM
mike@af's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: turbo fabrication
I dont do much 18-8 stuff either. I usually weld 4130 (20gage up), and mild nickel steels (22gage up). Most of the stuff I weld is usually done with TIG. I use MIG for tacking sometimes.
-Mike
Old 08-05-2004, 01:09 AM
Cbass's Avatar
TIG is something I want to get into, so far all of my experience is with stick and wire... I'm considering picking up a used DC machine and just getting a TIG torch and a gas cylinder, so I can get my feet wet with TIG welding.
Old 09-04-2004, 01:28 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Fabricating a turbo system???? well as far as plumbing goes its only moderatly hard...that is hard is fabrication a manifold for a turbo...i would suggest finding a turbo kit that is made for your car...buy just the manifold...then get a turbo off of another car...have the turbo sent off to have sealed bearings and lal that good stuff replaced...then fab up your plumbing....making sure that for ever 100HP or 10lbs of boost to retard your timing by 2-3 degress or bump your octane input 3-4 points to prevent detonation...or both to be completely safe...and for massive ammounts of boost replacing the bottom end in your engine and droping your compression ration a point or so will make your engin live longer happier....
