Old 07-23-2004, 04:41 PM
Raz_Kaz Raz_Kaz is offline
Re: whats faster in the 1/4
Originally Posted by Hotshot8792
it all depends on which cars you are driving, N/A imports . . the manuals will be quicker
turbo imports, 2WD the automatics will be faster, 4WD, will be very close
and yes, supra autos are quicker in the 1/4 than supra manuals, on turbo charged cars, autos can build more boost off the line than a manual can, and also an auto can hold boost in between gears. Now the reason mitsubishi never made auto an option in the VR-4, is when you have an AWD car, there's really no reason to have an automatic,
Not quite. Cars don't have 4wd, it's called AWD, difference being that 4wd is switchble whereas AWD stays obn at all times. Now getting back on topic here, the automatic turbo will be smaller than the manual turbo in most instances. So automatic will hold better boost but not enough power to overtake the manual car (and we all assume that the guy driving the manual knows how to shift properly)
Old 07-23-2004, 05:24 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I still don't.... How should I learn to take off into first real quick withought spinning my tires?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 07-23-2004, 05:39 PM
sLADe781 sLADe781 is offline
Originally Posted by Musashi3000GT
nothing, he went and payed $900 for a rebuild, he has no clue why it happened, niether does my sis. both of them are clueless about cars. Actually they got a flat the other day and my sis had to change the tire in the middle of the highway cause the dum ass dosent even know how to do that!
That's sad....what an idiot.
Old 07-23-2004, 11:32 PM
PearlGT PearlGT is offline
according to what i've read, brake boosting can be a deadly enemy to manuals everywhere from us autos, however it would have to be a fwd tt converted 3000gt to brake boost (glances at hotshot). ALSO the shift kit for our autos apparently makes a HUGE difference in our shifting in that the shifts are as quick as possible if set up right and eliminate quite a bit off of our 1/4 times, nothing as amazing as a tt conversion but still enough to make you happy. Lets not forget us autos still have a little bit of control if we choose to (its nothing like having a clutch and a 5 speed but we have L, 2, D od off and D od on) and i know of people who have been manual shifting off and on in their autos for over 100,000 miles and still no big issues.
Old 07-23-2004, 11:52 PM
Thourun's Avatar
Hrrrm, wish I could try out this short shif thing. Anyways I dopn't plan on haveing this car for too long, might sell it sometime during the school year, I want to try to find a good VR4 but there is only one on auto trader within 300 miles of me! Seems like they all got snatched up just before summer began, when is the best time of year to look into buying a VR4?
1995 3000GT VR-4
Old 07-24-2004, 12:58 AM
igota20hpweedeater igota20hpweedeater is offline
well, in theory an auto might be better in the 1/4 mile for turbocharged cars b/c during shifts the auto will maintain boost and the manual will have to build the boost back up after shifts. But my question is why do all the car and driver people clock faster 1/4 mile times in manuals rather than autos? I think its b/c manuals are better for the 1/4.
Old 07-24-2004, 01:35 AM
B00stCreep's Avatar
B00stCreep B00stCreep is offline
Don't manuals have the advanatge of shorter and closer gear ratios that keep them in the car powerband more so than an auto? I thought thats where they had the advantage
I have no car
Old 07-24-2004, 12:55 PM
Hotshot8792 Hotshot8792 is offline
on two wheel drive cars, autos generally get better traction off the line, on top of building boost
manuals have shorter gears, but i have come to discovered that the shorter gears on same cars dont make that much of a difference unless your just an absolutely great driver
on N/A 3/S cars, the reasons manuals are faster is cause the autos can't get off the line quick enough, now, i've seen an N/A 3/S auto race a N/A 3/S manual from a roll, and it was a dead even race
and yes, the shift kit does make a difference on auto cars, to put it like this, when i raced at the track, i could spike 5lbs of boost between shifts because it took that long to shift
as far as the automatic vs. manuals go, its really tough to say, just like on close races, it comes down to the driver, well, i guess when you compare the two cars, i guess it would all depend on the driver of the manual and the set up on the auto, or something like that. Its tough to say, i've put buslengths on a 6-speed VR-4 from an interstate pull before, only running 7 psi (10:1) to redline because of a boost leak, but then you'll have to look at drivetrain losses, and i had a full exhaust and LS6 MAFT, and he was probably completely stock (12 psi, 8:1)
I will say, BPU will make a big difference, one of my friends stock VR-4 trapped @ 76 on the 1/8 mile, other friends BPU RT/TT trapped @ 82, and although i trapped @ 86 on the 1/8, BPU had .3 seconds better than me on the 1/8 and stock VR-4 had same ET.
So as you can see, its hard to just say which transmission is better. A manual will definitely get you more control for sure, but an automatic will get you better consistancy. All i know is i'm just trying to see what an automatic is capable of doing, and i'm sure there will always be a 3/S manual out there much much quicker than me.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-24-2004, 07:34 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
straight line with equal traction and power, an automatic is faster in my experience.... my bros 99 GTZ galant is crazy stupid...on the freeway, at 80mph he rammed the accelerator to the floor and the damn tranny shifted to 2nd gear for a second or 2 (straight redlined) and then he metered in third... I never ever thought the ECU would be so poorly programmed that it would rather detroy the engine to get the car to haul ass... my other V6 is a 2000 Accord, and it never does that when I go all out.
Straight line, autos for sure.IMHO
The daily driver. The weekend cruiser. The lazy shop hog.
Old 07-25-2004, 01:32 PM
last night, at the street races
Camaro SS automatic vs. Camaro SS 6-speed
i saw the automatic barely edged it out
Old 07-25-2004, 03:07 PM
well, im confused...not really but i just have one question. For sport car stats y are most of them recorded in manual cars instead of in the auto? Wouldnt the people who record the 0-60 times and the 1/4 miles want the fastest times?
Old 07-25-2004, 05:23 PM
GrungeAholicVR4 GrungeAholicVR4 is offline
Actually, not to burst any hard core manual fans, because I have a 6 speed VR4, and i love manual transmissions, but, it is a very common fact that the fastest drag cars have automatic trannys. Pro-Stock Draggers, and Pro-Comp cars, were talking 5-6 second cars, use 2 and 3 speed power glide transmissions. They are similar to sports shift, or t-tronic shifters, still automatic and clutchless, they all have Torque convertors... I used to have a 69 chevy p/u before my VR4, it had a turbo 400 racing automatic tranny with a shift kit, the shift kit enabled me to program where the tranny shifts, and how firm, or soft it does it. It shifted faster than any manual I have driven, or seen driven...and it still had nothing on power glides...
The only place a manual is better than a good automatic is on top end highway runs...and still, its not by much..
Old 07-25-2004, 06:43 PM
yeah i know with torque converters autos will easily be better than a manual, but stock for stock which is better?
I have noticed that my manual 300zx is faster than my auto one, by feel and by the g-tech stats.
Old 07-25-2004, 07:10 PM
dont always base everything on how it feels when you drive the car, gear ratios can be deceptive
shorter gears (which are found in manual cars) will make any car feel faster, yet, does not necessarily mean that it is faster
for example: my buddies WRX feels much quicker than mine, yet, everytime we have raced, i walked him without any problem at all.
I think manuals are fun cars to drive, and as far as drag racing, i honestly think it can go either way, all depending on the set up of each car.
Old 07-28-2004, 08:39 AM
Italian Lunaticz Italian Lunaticz is offline
Send a message via AIM to Italian Lunaticz
auto
hey how much to put a high-stall torque converter or shift kit on to my auto gt?
