Old 07-17-2004, 11:44 PM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
Re: Paint, Primer, Clear Coat, ect. advice
i use TAMIYA everything, tamiya paint, tamiya glue, tamiya sandpaper, tamiya putty, tamiya epoxy putty. i am biased because i only worked with tamiya products only. heheh
friends let friends drive benzes
Old 07-18-2004, 12:28 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
what grit sandpaper is your work horse type paper? The one which you use to clean up parts where you cut them off the tree?
Old 07-18-2004, 08:46 AM
Vric's Avatar
Vric Vric is offline
Take a look there for basinc about cutting ans assembly
http://www.tamiya.com/english/scale/beginner2/1.htm
Also few good basic tutorial by tamiya there:
http://www.tamiya.com/english/scale/beginner2/index.htm
There is also more advenced technic there:
http://www.tamiya.com/english/howto/howto_top.htm
Old 07-18-2004, 11:02 AM
thanks alot for those! those are pretty handy. What sandpaper do you use for general sanding though?
Old 07-18-2004, 11:58 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
I use 3M sandpaper (Automotive), 800 to remove mold line's then sand the whole body smooth with 1500 before painting.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 07-18-2004, 02:21 PM
Vric's Avatar
I have 320 (for big putty work) 400 600 800 and 1500 grit.
it's not for polishing, only for building
Old 07-18-2004, 03:18 PM
i use alot lower grits than that. I sand tree marks with 80-100-150 sand paper...depending on how high the mark is. Then progress to 250 all the way to 800. Is this not a good thing?
Old 07-18-2004, 04:26 PM
Vric's Avatar
I would say higher than 350 is too hard on plastic part.
