Old 07-17-2004, 11:31 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
I use 2000 grit 3M and it work's fine for me, Just make sure you keep water on the paper otherwise it will go right through the paint.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 07-17-2004, 12:27 PM
doucmehu's Avatar
doucmehu doucmehu is offline
Re: Can you wetsand a painted shell with 2000 grit paper
2000 grit has worked for me, too. If you are putting more coats over it, it should be fine. Just don't push hard when using the 2000
VeeDub!!
Name that song - "Pull on the trigger and the nightmare stops"
