Old 07-11-2004, 02:27 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
Re: Re: turbo my B18, or LSvtec?
Originally Posted by TheSilentChamber
I bet theres more horror stories about turbos than about vtec
Both set-ups can be horrific if not built well. At the end of the day it all boils down to cost, taste and reliability! For a cheap, all motor and reliable set-up, I'd go B18C. If you have a little more cash to burn the options are endless. In my experience however, LS-turbo will walk Ls-vtec all day.
Old 07-12-2004, 12:20 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Thanks for the input guys!
i'm gonna get some F1 cams for my LS motor and toss a T3 43/47 with 2" piping and DSM sidemount and see where i come out at on the dyno
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 07-12-2004, 12:22 PM
oh yeah DSM 450's and fmu as well as fuel press. reg and 1g bov.
gonna run 9lbs.
in about six months i'll drop 800$ on lower comp. pistons and new rods and headbolts etc and then run about 18lbs
-Josh
projects:
Old 07-12-2004, 06:06 PM
91civicDXdude's Avatar
gonna run 9lbs.
DSM 450's + FMU = no.
you dont use them in conjunction. an FMU raises fuel pressure per psi of boost. larger injectors flow more cc's of fuel at the same pulsewidth.
maybe you should do a little more research into fuel management, becaues you'll find that an FMU in conjunction with DSM 450cc injectors will not run, and in the (very) unlikely event that you get it to idle, it will run so rich that you would get 3mpg and smoke out a cloud of black smoke so thick you wouldn't be able to see the car.
honestly. research your fuel management options a little better.
Old 07-12-2004, 06:54 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
do you know why these guys arent making the hp they should. because htey do an ls vtec, put cams and pistons in but they still run the car off the stock ecu. you gotta get an aftermarket ecu like hondata or uberdata or whatevers to tune the car for the ls vtec with all the parts it has
Team Lonely Drivers
Old 07-13-2004, 06:36 AM
this is tru!! never thought about that!
Old 07-13-2004, 11:10 AM
oh snap!
meant afc not fmu.. mybad.
btw not the first time i've turboed something.. i was looking for a challenge so i was wondering more about lsvtec.. drivin honda's doesn't provide much challenge in the mods/workin on dept.
that's why i converted to RWD with my other hatchie and tossed a 350 in there.
-Josh
projects:
Old 07-13-2004, 01:41 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
I would go turbo before going vtec anyday. Turboing a car is less expensive and in the long run, more power can be made with less money than with adding a vtec head. You don't just replace the head gasket and slap on a vtec head.
There are many things that come into play. Yes, you'll need a new head hasket, in addition to many other things; a vtec head, vtec ecu, external oil feed line, new timing belt, new vtec water pump, new head bolts, new vtec oil pump, etc..the costs keep adding up.
You're gonna want to replace w/ new bearings (rod and main), oil pan gasket, main seal, oil, oil filter, oil return gasket.
In addition there are many things that can't be done on ur own. your gonna need the rotating assemble balanced, your gonna need to do some welding to close the vtec oil galley in the head
In addition, if you want this to be a reliable setup, and to make the power that adding a vtec head is capable of, you're gonna want new pistons, rings, and rods.
Now, 99% of this work, most people don't have the knowledge, experience, or tools to do...so it has to be done by a shop which doubles the cost of the swap.
You're gonna need someone to wire the vtec which isn't that hard but requires someone knowledgeable about wiring.
This all just keeps adding up and up...can be anywhere from 2k to 4k to add vtec to a non vtec block.
Also, the motor must be out of the car to accomplish this.
Adding turbo is alot cheaper, more reliable (IMO), and is removable if needed.
If you go with a junkyard setup...you can boost relatively cheap...for under 1k...probably alot less than that if you take ur time and catch deals that pop up.
Turboing requires less components and work. If you get a turbo, EVERYTHING else can be fabbed up at a shop that welds. In addition you may want an intercooler, and a blow off valve.
If you only boost 5-7 lbs (which is perfectly safe..even without major tuning), you can be making the same power as adding a vtec head...and it is more reliable. If you want to turn up the boost, it just requires some good tuning. When people here tuning, they get scared and expect to have to do alot of work...it's not. It's as simple as creating a good fuel mixture for the motor to cause it not to have detonation. Turbo motors LOVE the extra fuel. It's better to have way to much than not have enough. With a little research, you can start to slightly tune the engine yourself, with like an Safc....taking you out of that RICER stage...lol. There are plenty of ls motors taking 10-15 lbs of boost on tuned engines...over 200Hp...closer to 250.
BTW...
I'm curious on everyone's opinion on what would be a decent setup on a B20b...
thinking a tuned s-afc, some DSM 450's, an ebay turbo mani., and a IC from like a saab. I'll use the radiator from a 92-95 civic. I want a turbo that would be nice in the range of 2k to about 6k. I wont be revving over 6500 on this motor. Should my 2.5 piping and 2.5 cat be sufficient at low boost until i can get a 3' welded up?
Civicdude...whats ur opinion. I know u own a D-series but im curious on what ur setup is and what u think.
P.S..
all the information posted above is Just my opinion. Everything stated is (IMO). This is a message board and that is what it is used for..everyone is entitle to their OWN opinion. Please no flaming from you vtec guys.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 07-13-2004, 03:50 PM
the rex i ran 25lbs with was 2 1/2" exhaust.. no cat tho it was straight out the back.. i think the 2 1/2" was plenty.
i could do 99% of the work for a built LSvtec in my garage. sending the crank/rods/pistons out to get balanced would be the only thing i can't do on my own
BUT.. this is a budget car, the fast one (Teh V8) is built enough and has enough money sunk into it. this is my budget daily driver.. the LS pulls nicely but i was looking for a relatively inexpensive mod.. i think i'm going to just turbo it.
I have another project in the works for LSvtec tho.. I just have to keep my eyes open for the right car to put it in. I'm going to make a Bseries to GM adaptor plate and mount a powerglide to an LS block.. LSvtec turbo that for a RWD drag car.. probably a rex but maybe just maybe i'll find an inexpensive del sol
-Josh
projects:
Old 07-13-2004, 05:40 PM
BTW...
for a b20 only revving to 6500, i would suggest a T3 Super 60. .60 AR compressor/.48 AR turbine. with that particular combination, you're going to reach full spool very quickly (2500-3000 rpm estimated) and hold it all the way to 6500 with the 60 AR compressor. A larger turbine would raise your spool and shift your powerband beyond your rev range.
your 2.5" pipe should suffice, as long as you know that 3" will make more power. the rest of your setup sounds good.
I've heard a lot of rumors that the B20 blocks have weak sleeves and blah blah blah, but i doubt they are weaker than d series sleeves which can hold 20psi easily.
My thoughts on the AFC hack:
(i wrote a big ass reply on this and for some reason it didnt save it so now im going to give only the abridged version. ifyou want more specific info, pm me)
The AFC hack, for those who dont know, is a method of using an AFC to accomplish 2 things: control the flow of larger fuel injectors allowing the car to idle, and "bypassing" the need for a missing link or check valves to bleed off boost from your MAP sensor, which will throw a check engine light when the ECU senses the map sensor is outputting over 1.3psi, or roughly 3 volts. The stock map sensor can actually read up to 10-11 psi, but its the ECU that freaks out. The AFC accomplishes this task by scaling the voltage of the map sensor down, keeping the peak voltage output below the threshold of check engine light. You accomplish this by subtracting -35% to -40% from the AFC's fuel mapping, thus the need for larger injectors.
The problem with the AFC hack:
As you know, timing retard is crucial on forced inducted engines, especially hondas which werent' made for boost. One problem with the AFC hack (due to how it works) is that it is reading from a different part of the fuel and ignition table than the car is actually running at. As a byproduct of scaling the map sensor, you lose resolution in the table (the amount of tuning points). This means that under low boost, you are reading from the lower left hand corner of the ignition table which is very advanced. LOW BOOST + AFC HACK = VERY ADVANCED TIMING = VERY BAD to counteract this, you need to run as much boost as the stock honda map sensor will allow, which will let you use more of the ignition and fuel tables.
my advice: run 7-10psi on very conservative AFC settings. retard your ignition timing 4-8 degrees at the distributor. enjoy boost.
P.S. - FYI, i believe that an LS VTEC (stock block) can be built with about the same amount of money it takes to build a turbo kit, and they will reflect that amount of money you spent. This said, would you rather have 160hp or 220hp for the same price?
I know which one i would choose. boost baby.
