Old 07-28-2004, 09:27 PM
96camaro 96camaro is offline
Re: COde: P1870 [Transmission Component Slipping].. Help!
450? Kinda of pricy though.. Its probably that price range if you bring it to a middleman tech.. meaning he will bring it to a tranny expert instead, and pocket some.. This is pretty common. I went to a "backscene" tranny shop, which does not entertain walk-in customers.. they only do "referred" cars..
Old 07-29-2004, 01:18 PM
LiquidSmooth LiquidSmooth is offline
Send a message via AIM to LiquidSmooth
I bought it straight to the shop where i say them pulling one out of a 350 chevy work truck to do whatever, in this case there was no middleman!
Old 07-29-2004, 01:26 PM
I just called and there's only an hour to an hour and a half till i get my baby back!@#@$@!%$#@%#@^
Old 07-30-2004, 01:00 PM
man... you probably can use one from ebay..
Old 08-10-2004, 06:43 PM
sosren sosren is offline
had the same problem with ny 96 ses light came on 3 separate times. 3rd time they tore the tran apart and replaced the valve no problems since then.
Old 08-11-2004, 10:48 AM
Thunderbolt Thunderbolt is offline
Re: Re: COde: P1870 [Transmission Component Slipping].. Help!
Originally Posted by 96camaro
I am back!!
Got my camy to the tranny expert and had the valve body replaced with a brand new one. Got new gaskets/plates, and transmission oil as well.. Pretty reasonable.. Cost me about $270 (I think so).. Heard that it was about 350 & up for others.
And yeah, it all started with SES light on.. 1870 code diagnosed..Cleared it.. Popped up again... Cleared it... Popped up again after highway miles.. so far..its been a month... so far so good... Glad I did not take for a tranny rebuilt as some advised..
That is one of the most common causes of the P1870 along with the plunger for the TCC solenoid. Replacing the valve body is one solution and if it is the plunger bore they have a kit to slightly overbore it and put a new plunger in. Either way $ 270.00 is cheap.
