| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#16
Re: Airbrush user, we need you !
Airbrush: BB Rich Japan Model AB-300 [equal to Iwata HP-C]
Paint Brand: Gunze, Tamiya Paint Type: Acrylic, Enamel Mix Ratio: 3/1 PSI used: 12.8 kPa (=1.87 PSI?) Low pressure air compressor Thinner used: Gunze Mr Color Thinner, Gunze Aqueous Hobby Color Thinner, Tamiya Acrylic Thinner, Tamiya Enamel Thinner Cleaner used: Commercial lacquer thinner, Gunze Mr Tool Cleaner, Isopropyl Alcohol, Tamiya Enamel Thinner Last edited by shieldwulf; 07-02-2004 at 01:36 PM. |
#17
Airbrush - Aztec A720s, double action setting
Head - Grey General, Black for Acrylic and Laquer Compressor - Medium tank with double moisture traps, twin regulators with twin air feeds. Preassure 15-20Psi, no more. Paint - Tamiya Acrylic Thinner - Tamiya Clean with - thinners and or water Paint - auto laquer Thinner - various laquer thinners depending on desired flashing time. Fast for base, slow for wet/clear coats Paint - Enamels Thinner - cellulose thinners, medium flashing Paint - Alclad Thinner - N/A Clean-up - cell. thinners. Ratio - Depeneds, start 50/50 and go from there. Should be milk like. Same goes for pretty much any paint really. Hope that helps. I'm still learning 15 years after getting my first airbrush!
My current work- ![]()
#18
That was agood start, I just bump up this one
![]() CarsModeling.com. My Scale Model Cars blog. |
#19
Should this be added to the FAQ? I think it should.
-Mike AF Director of Media / Photographer ![]() [email protected] | AutomotiveForums.com | Flickr Gallery |
#20
Re: Re: Airbrush user, we need you !
#21
Airbrush Model : Aztec A470
Paint Brand : Tamiya Acylics / House of Kolor Paint / Spies Hecker Mix Ratio : 2 parts paint 1 part thinners / HOK (already thinned to airbrush use ) Pressure: from 1,5 to 3 bar Thinners : Tamiya Thinner / Nitro Thinners Cleaner : NitroThinners
IN Progress Fujimi EVO 5,6,7,8 with HOK Kameleon Colors http://www.automotiveforums.com/vbul...9&page=1&pp=15 |
#22
Paint Type: Enamel, Lacquer, Acrylic, synthetic lacquer and 2-part automotive enamel. Mix Ratio: Each bottle of paint requires a different mixture of thinner to paint. I generally start at 1:1 and adjust from there. PSI used:(how many pressure you use ?) It depends on what I'm shooting. Generally 12-15 for gloss or semigloss coats. 15-20 for semigloss and 20-25 for Metallizers. Thinner used: (Type and brand) Model Master (black can) for all enamels. Tamiya acrylic thinner for large semi-gloss surfaces and metallics. Windex, IPA and a little bit of liquid soap for flat coats or small pieces. The decanted Tamiya TS paints, while thinned already inside the can, get an additional shot of "general purpose paint thinner" to slow the drying time and help the paint flow-out. Alcad2 uses no thinner. Nason uses the "gp paint thinner" from above. Cleaner used: (What you use to clean your airbrush with this type of paint) Simple Green breaks down all acrylic and enamel paints. Windex and IPA will clean strictly acrylic and straight acetone will clean EVERYTHING and it's very cheap too boot. Bill p.s. I use an Aztek A470 with a Badger silent air compressor including tank, moisture trap and regulator. |
