#16
hello im still waitng for hellp on the back side info on the z6 intake stuff and well a pg7 ecu work for this set up?
#17
Re: help im trying to do a mpfi but i never get the right parts
the thing you're referring to is the purge solenoid. Im guessing that its missing. there should be a bolt hole on the back right hand side of the intake manifold, away from the throttle body. directly underneath there is a vacuum port. Located on the firewall, next to your map sensor, there should be a purge solenoid. One side of it is connected via a vacuum line to the black charcoal cannister also located on the firewall. on the bottom of the purge solenoid, there is a vacuum nipple from which you want to run a vacuum line over to that vacuum port on the back side of the intake manifold.
and yes, a pg7 will work great with your setup. |
#18
thanks for all your help thing thing i need ot ask
if that purge is not on the intake can i use the one on the firwalla nd be fine run dose any one have pics they can put up soo i can see to make sure i have eveyrthign i really dont want to go to put it together and not have eveyr thing...
oh yuaeh i sitll need a good tps any ideas |
#19
i found out it is the evap purge control solenoid valve and i think that is all im missing on the intake soo is the one on the firewall ok to use like you were saying to keepin it running thanks for all your help again
#20
read my above post.
#21
yes the pg7 will work, its one of the few thing that will work from an integra
