Old 05-29-2004, 09:11 AM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Re: Pistons...
I wouldnt be able to run on pump gas then would I ?
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 05-29-2004, 11:21 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
lol..i'm not to sure about that one.
if you're worrying about still being able to run on pump gas, i think 11.0:1 should be fine?
Old 05-29-2004, 01:13 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
you should be able to run up to about 11.5:1 on 93 octane safely with no worries i believe, after 12:1 its a risk.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 05-29-2004, 02:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you run 11.5 cr, then i would run a type r ecu, unless the type r's had bigger injectors, anyone know ? if they are the same as everyother civic and integra injector and only flow 240cc then i would run teh type r because it comes stock with an 11.5 so it should be able to control that high of cr
Team Lonely Drivers
Old 05-30-2004, 07:02 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Pistons...
Just a little FYI, the B16B is a destroked B18C ITR motor, not a built B16A. Different deck hieghts.
