#16
Re: program keyless remote
Is there any way possible to program this remote without a trip to the dealer. ( 96 T&C)
I have two remotes and neither are original, they both have been purchased used. Thanks. |
#17
Re: Re: program keyless remote
RM-TECH |
#18
Re: Re: Re: Re: program keyless remote
I have one programmed but want to add a second one. Many Thanks! |
#21
Hi:
My is 2001 Voyager LX, I got one remote with the car and get a new one from the dealer. They tried to reprogram the new one with DRBIII but can program only one REMOTE. I tried with the method in the service manual, but still only one work. The service manual did not say you need to program all you REMOTE before turn OFF. (The working one would be erased to BLANK) Program ALL you REMOTE one by one before turn OFF. I just programed two REMOTE. |
#22
I have a 1999 and I have no working fobs. The program method D does not work because I have no dark green wire and there is no wire in #1 of the data connector.
Hello,
I'm new here and I have a question, I hope that someone can help me!! I had to replace my battery in my keyless entry, I tried to hold the buttons for the 7 seconds and nothing is happening!! I just bought a new stereo for my car and everywhere I have looked on line is telling me that I need the stock stereo!! I'm wondering if there is another way to make it work without having to put my old stereo back in my car and then putting the new in again? I'm going crazy here!! Please help!!
#26
I had a 97 Grand caravan and still have 2 working remotes. These are rectangular remotes. I just got a 2000 Grand caravan that has 1 peanut shaped remote. I tried programing the '97 remotes via the 2000 owners manual instructions without luck. Can the '97 remotes work with the 2000 Grand Caravan? I hope I don't have to buy different remotes for the 2000.
Thank you, |
#27
How to Program 1996 Chrysler Town & Country LXI Remote (taken from owner's Manual p.18) This feature allows you to program transmitters in case one is lost or an extra transmitter(s) is desired. Up to 4 transmitters can be programmed to your vehicle. To program another transmitter, follow these steps: 1.) Turn ignition switch to the ON position and leave vehicle in park. 2.) Using a previously programmed transmitter, press the UNLOCK button for 5 to 10 seconds. While the UNLOCK button is being pressed, press the PANIC button and release both buttons simultaneously. You will hear a chime sound to signal you that programming on the new transmitter(s) will occur. 3.) Press and release any button on each transmitter, including the previously programmed transmitter, you wish to program (up to 4). You will hear a beep when a transmitter has been successfully programmed in. You will have 30 seconds to complete the programming of all desired transmitters. A chime will sound when the 30 seconds is over, or if you turn the ignition switch off. ~~I hope this helps anyone out there.
#28
I know how to program the remotes that DO NOT HAVE THE PANIC BUTTON... they are the black square ones with just lock and unlock. What I did was turned the ignition to on without starting the motor, keep the driver door open, then with the original working remote i pressed lock for like 10 seconds.. The locks go up and down many times. I then took the new remote and pressed lock for a few seconds and it now works fine.
#29
