Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-22-2004, 12:27 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
i never said the quadrajet was hard to rebuild. i just wouldn't take your first stab at rebuilding a carburetor at a quadrajet. i've rebuilt quad's,holly's,even the ricer carbs on the early sentra's. and actually, i think the Carter carbs are easiest to rebuild, but not a big fan of em
Old 04-22-2004, 11:13 PM
Twin89s's Avatar
Twin89s Twin89s is offline
Send a message via ICQ to Twin89s Send a message via AIM to Twin89s
For a stock to mild 350 Holley Street Legal 600cfm carb should do you good. it is in the jegs and summit catalogue's. Also the name says it all. Street legal lol
  #18
Old 04-22-2004, 11:21 PM
crapmaster4000's Avatar
crapmaster4000 crapmaster4000 is offline
If you know what you are doing with cars, why not try putting fuel injection in your car. Its alot more reliable than a carb and they start up in the winter too.
  #19
Old 04-22-2004, 11:28 PM
Twin89s's Avatar
new carbs electric chokes arent bad.... Seriously my cordia sometimes starts better in the winter than my TBI and my tbi pretty much fires right up.
EFI can be a bitch to install if you dont currently have it. Sometimes its too much to take on and too pricey compared to the price of a new carb.
  #20
Old 04-22-2004, 11:30 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: rochester quadrajet
so then whats wrong with a holly spread bore. oh and incase you didnt read it, the one your talking about also says... "installaton on spreadbore-style manifolds, howerver, requires an adapter plate for proper mounting". im betting that the spread bore would be a better carb than the square bore, and would be more of a bolt on and not require aditional parts.
  #21
Old 04-22-2004, 11:32 PM
yeah EFI will be like 2 grand or so and a carb would onyl be a couple hundred dollars.
  #22
Twin89s's Avatar
the adapter is 20 bux at autozone. I sold my old 600cfm carb to a guy with an 83 I think it was Z28 and he reported a gain to me and the carb prolly could of used rebuilding!
  #23
Old 04-22-2004, 11:38 PM
yeah, the only thing i like about a holly is that it seems to have a little more responce when you first hit the gas but i hav run hollys, (sguare bore), my quadrajet, and my dads old spread bore holly on the same engine. i would not chose the square bore for anything unless i was more concerned with economy maybe. but even so you can tune the quadrajets to run perfect on the primarys and then still have the big secondaries when you hit the gas. there is a big difference when the seconaries open up. not with a square holly though. if you havnt riden or drove a car with a strong engine and a properly tuned quadrajet i highly recoment everyone should. there is a big difference.
  #24
Old 04-22-2004, 11:40 PM
Twin89s's Avatar
I rode in his car with the decently tuned quadrajunk it wasnt much... now I havent ridden in it with the new holley but from a stop just flooring the throttle it will spin them a bit longer from a stop.
  #25
Old 04-22-2004, 11:50 PM
thats a bummer you dont like in cali. i would take you for a ride and show you what one can really do, and then come back and put on my holly and show you what they dont do.
  #26
Old 04-22-2004, 11:53 PM
tacoma man tacoma man is offline
i called a salvage yard today and they have
several tuned port engines out of 91-92 z28's
for $400.00 i can buy the whole engine and
get the wiring harness and anything else i need
off the car to make it run.
  #27
Old 04-22-2004, 11:56 PM
well that doesnt sound to bad.
  #28
Old 04-23-2004, 12:26 AM
Twin89s's Avatar
where the hell do you live? around here they like to 300-400 just for the tpi injectors plenum runners lower manifold.... 500-600 for the wiring harness and computer with the complete TPI setup.
  #29
Old 04-23-2004, 01:05 AM
4onFloor's Avatar
Re: Re: rochester quadrajet
eh brand new maybe. the engine in my sig was a quadrajet at one time. which i know tbi is cheaper than tpi, hence the fact that it's not a tuned port. but for the throttle body, dist, coil, sensors, harness, and lots of other things cost me $180 used. which is a small price compared to whats sitting inside that block. But i just wanted something reliable and fairly fuel efficient but yet good enough to hold it's own when cruisin. dont really care too much about 1/4 miles times, and even if do go that path there's always bolt on mods.
and imho, anyone who pays $2000 for aftermarket fuel injection is nuts. the holley projection and holley mpi system are a rip off. it's a closed loop system, so you throw engine codes out the window. and they charge you an extra $100 just for an O2 sensor.
Old 04-23-2004, 01:19 AM
yeah i ment new. i have debated on putting EFI on my car. its not built for long cruses, but i sometimes drive it up to where we go fishing,( a 6 hour drive), and we go up in elevation and then my car just dogs down. also i wouldnt mind getting the little amout more MPG that i would get with EFI. i dont think it would be alot cuz i do have my carb tuned extreamly well, well until i switched jets and screwed everything up. do you like the TBI on your car. im not to crazy about it but it would be an easier swap wouldnt it?
Closed Thread
