| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#16
Re: Revell Honda Civic SI Coupe
Re: Re: Revell Honda Civic SI Coupe
I appreciate the kind words. The Civic was a fun kit to do. The only drawback is those irritating little screws that fasten the chassis to the interior/body. As for the chrome on the chassis parts, it's Alclad II. |
#18
Re: Re: Re: Revell Honda Civic SI Coupe
Re: Re: Re: Re: Revell Honda Civic SI Coupe
I use the basecoat that is recommended by the manufacturer - Testor's Gloss Black ENAMEL. Either the regular Gloss Black or the Model Master works equally well. |
#20
dude that is soooo bad ass ....a couple of questions, how did u get some of the parts chrome and how did u lower it
#21
The "chrome" on the chassis and suspension parts is Alclad II that was applied with an airbrush as per Alclad's instructions. The extra chrome under the hood - the strut brace and airbox - were covered with Bare Metal Foil. Here's how I lowered it:For the front suspension I just removed one coil from each of the front strut springs, as well as the mounting pin. I then drilled the top of each strut and attatched a new mounting pin made from piano wire. Also, the mounting points on the chassis for the front subframe needed to be adjusted. On each of the front subframe mounting points, I removed the same amount of plastic as the width of the coils that were removed from the front struts. This enabled the front end to be lowered just right! For the rear suspension, I also removed one coil from the rear strut springs and made a new mounting pin. On the rear suspension arms, a bit of plastic was removed from the flat portion of the bottom surface where the rear suspension mounts to the area of the chassis just behind the fuel tank. Some minor tweaking was needed but I think the stance is much improved over stock. This should lower your overall suspension just enough to give the model some much needed "attitude"! HTH |
#22
If I were to build the kit (and I probably will, along with a matching Civic Hatchback)... I'd probably do it in a JDM fashion.
-black headlight housings -no chrome "Altezza" taillights, only black/carbon fiber -no chrome wheels -very little chrome in the engine-bay. -lower the car as low as it will go (tuck the wheels), without a "lowrider" stance.
jdm taillights arent black
#24
Yes, I realize that, and the JDM taillights also arn't "Altezzas", are they?.... the taillights on the civics are Chrome housing altezzas. Mine won't be chrome, they'll be black/cb/smoke.
yea mine isturning out real nice you can find info about it on page one
#27
it is under the name custom crx and i had to create this account becaus i lost the password to the other account
