Old 04-15-2004, 10:28 PM
mel_carramel's Avatar
mel_carramel mel_carramel is offline
Send a message via MSN to mel_carramel Send a message via Yahoo to mel_carramel
Re: Help on Thinner... HOW to is not included..
i bought the tamiya epoxy putty.. when i open, i saw two color strips... white and yellow.. and the instruction is in JAPANESE.. i cant understand..
what do u mean by mixing together? take some of it both and use water?? or just add like play-doh??
im going to the store again today to get myself the window cleaner... and the isoprophyl... and the a bottle or two of distilled water..( battery water right??) thanks to you and the rest for helping me out in figuring out this.. my LHS is sometimes frustrating.. they dont even have Pla Plates.. can u believe it?
Old 04-16-2004, 08:47 AM
Ok.. im back from the store.. i tried at more than 7 drug store and pharmacies.. none of em knew bout isopropyl... but i got something else.. they gave me this instead..
can i use this and add 1:3 with distilled water??
Old 04-16-2004, 09:13 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Mix it just like play-doh(!). Figure out about how much you'll need, cut half that amount off of both ribbons, squish 'em together and knead until it's all one color. Water isn't needed. I haven't ever used the Tamiya stuff, but with other types of epoxy putty I've used, a little bit of water does help soften it and make it a bit more flexible for shaping. It doesn't seem to add any time to the curing process. I doubt it would be any different with the Tamiya. Just add a couple of drops at a time, as you would to play-doh! to make it squishier.
It helps to have some tools to shape the putty as you're using it. I use a short lengtht of wooden dowel, sharpened in a pencil sharpener, and painted gloss white (to lessen the putty from sticking to it).
Yeah, battery water. Funny, I don't usually think of it as such, but that's exactly the stuff.
To make paint mixing easier, I mix up the isopropyl and water in a small plastic dropper bottle (I use an old emptied contact lens solution bottle). I then add paint to the color cup on my airbrush, and add the thinning mixture by the drop, until I'm happy with the consistancy (test spraying is a necessary step in this). When done spraying, just squirt the window cleaner into the color cup and go.
Old 04-16-2004, 09:24 AM
MPWR's Avatar
Re: Re: Help on Thinner... HOW to is not included..
OK, I'm going to guess that that's methyl alcohol. If so, then it should work fine for you. Methyl alcohol is used, among other things, for sterilising surgical instruments, so 'surgical spirit' would make sense.
Let me guess, Singapore?
Old 04-16-2004, 09:40 AM
no.. malaysia... ehehehehe..
