Old 04-15-2004, 04:45 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Re: What are your opinions on the EVO3 16g?
yeah i knew we were talking about psi of boost and obviously there are number in between 8 and 9 such as 8.5 etcedra...but i didn't know you could set your boost between 8 and 9 psi. i know 1 bar is 14.7psi well what would 8.75 psi be?
Old 04-16-2004, 05:16 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: What are your opinions on the EVO3 16g?
probably .8 or so. and why not, if it is a MBC it is an analouge screw, right? you just adjust it a little bit.
Old 03-05-2005, 01:40 PM
mikep1117 mikep1117 is offline
Send a message via AIM to mikep1117
what all mods would i need to not get boost creep if i have a full 3 inch turbo back exhaust with a evo 16g would i just need to port my o2 and then upgrade my pump injectors and get a afc
Old 03-05-2005, 04:57 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Search for boost creep, especially on DSMtuners.com. DO you know that this post is 11 months old?
Old 03-05-2005, 11:11 PM
kjewer1 kjewer1 is offline
AF - Advisor
I'd rather see him add his question here than start yet another thread on boost creep. But the only thing in common with the thread is the 16g, which is almost unrelated to the boost creep At any rate, I know I've posted extensively about it in this very forum Mike, try a search using this forum and my user name as search criteria, and see if you dont come up with some helpful information. If while reading one of those threads you have a specific question about some aspect of it, by all means feel free to post the question in that thread. I would rather keep all the boost creep questions in a boost leak thread, as it will make it easier for others like yourself to find more information in future searches. Enjoy.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-07-2005, 08:50 PM
Burton4g63 Burton4g63 is offline
wow this thread confused the shit outta me is this right?
a full 3 inch turbo back system with a 16g will have boost leak?
Old 03-07-2005, 09:51 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
lets say you get a exturnal waste gate and you have a turbo with a inturnal wate gate, do you just take the vacume line off the inturnal one and put it on the exturnal ? . or do you need to weld the flapper shut or somthing like that?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-08-2005, 03:01 AM
LMAO...
you are probably going to get some boost creep. when i mach it out and get up to ~140mph [ping the speed limiter] i'm well above where my boost is set at. and my EGT is over the warn light too. so i've got 2 red warning lights staring at me. stupid creep.
Old 03-09-2005, 08:45 AM
AF - Advisor
If the external gate is manifold mounted, you weld the flapper shut. If it is O2 housing mounted you remove the flapper and fist it with your die grinder. I have run manifold mounted gates while still retaining the stock flapper and actuator out of laziness, but it still blew open. Wiring it shut stopped boost from dropping, as evidence.
Kevin Jewer
