Old 05-08-2004, 10:09 PM
kiinge kiinge is offline
Re: How Many Miles on Your Lumina
red 1991 lumina Z34= =227,000 .
Old 05-09-2004, 07:55 PM
Corndog Man Corndog Man is offline
Re: Re: How Many Miles on Your Lumina
Black '99 Lumina LTZ. Just turned 90K. Solid except the sun roof. See post about that.
Old 05-09-2004, 09:51 PM
1991 Z34 =227,000 -the engine itself is still running strong.oh yeah i have had my share of problems with it mostly alternators 3 too be exact. and the timing belts and pulleys it runs on...2 sets of those.i have the local shop do that.there hard too get timed but he does it right..i just replaced the starter with a Delco. but when i dropped the frame in the front too get too it, i developed a small leak on the hose that runs the passenger side of the frame...it was rusty.. so i am glad it happened now instead of later...i have no idea where the back of that hose runs too...i presume that i will have too pull the engine ahead too get too it...any ideas where it goes into,on the rear of the engine? and also i noticed that the boot on the inner transaxle is split.
Old 05-16-2004, 12:03 AM
TaiN's Avatar
TaiN TaiN is offline
1994 Lumina APV 3.8 183k rebuilt tranny, nothing big on engine.
Old 05-17-2004, 02:14 PM
cgin59 cgin59 is offline
I have you all beat! I have a 92 lumina 3.1 with 303,000 on it. Rebuilt the engine at 275,000. What have I replaced? Water pump, Alternator, Intake manifold ( water outlet corroded into manifold - dissimilar metals), AC compressor (3 times), Fuel pump 3 times (always replace with a delco brand- Brand X pumps fail after 6 mos. with oxy- blend fuels), water level sensor (corroded), struts (all), This car is notorious for bad brakes!, rear fiberglass suspension spring. Looks like the engine will outlast the seats and dash board! Oh well....It still runs like new! Can't believe the transmission is still running smooth. Change the fluid often!!!
Old 05-17-2004, 10:24 PM
In_Style In_Style is offline
91 Lumina Euro Sport 403 000 miles = 650 000 km.
Nothing major done to the engine. Burns no oil
Old 05-18-2004, 07:49 AM
Lumina95 Lumina95 is offline
1995 Lumina 3.1L 140k
Headgasket went at 120k, radiator rodded out, so many new parts even catalytic converter.
Still running good.
Old 05-18-2004, 02:02 PM
conley conley is offline
Send a message via AIM to conley
I have a 92 LHO Lumina 3.1, and it has about 205,000 miles. Not running right now for some reason, but I did an engine swap after the timing chain broke in the old engine. POS.
Old 05-22-2004, 11:55 AM
lakahahahman lakahahahman is offline
1990 lumina sedan
2.5 4 cyl with 427.693 miles on it
had one oil change in last three yrs
one muffler and everything else is original
Old 05-22-2004, 10:38 PM
Metal_m_a_n Metal_m_a_n is offline
Send a message via AIM to Metal_m_a_n Send a message via MSN to Metal_m_a_n Send a message via Yahoo to Metal_m_a_n
I got a 92' Eurosport with a 3.1L with 143K and the only major probs I have had with her is the compressor clutch...It kept on tearing up belts so after 3 of those I decide to just pull the whole thing out(I know I could have got one from a junkyard for like 60 bucks but I lived in cold michigan when I did it so I didn't see the need)....I tried forever to find the pully out a Lumina that didn't have a/c but couldn't find one so I just got a pully to fit the serpentine belt and bolted that on one of the bolt holes for the compressor....I did bust one of the super corroded coolent lines when pulling the compressor but I juse cut a few feet of the corroded part out and clamped some heater hose on it....Other than that and the alternator which was no biggie shes been pretty good to me.....
Old 08-07-2004, 09:34 PM
DoorsfanX DoorsfanX is offline
Send a message via AIM to DoorsfanX Send a message via Yahoo to DoorsfanX
I have a 1993 3.1 with 150,215 on it. although it runs strong it loves to stall and make me wait 7 to 15 minutes between starts and does this constantly for about and hour and then after an hour it usually runs fine...but when it isn't too busy stalling it runs like a champ.
Old 08-10-2004, 02:56 AM
kevin716 kevin716 is offline
97 lumina
just rebuilt engine at 83,000
Old 08-11-2004, 12:52 PM
Thanna00 Thanna00 is offline
Originally Posted by GTLumina
I have a '97 with 3.1 engine with 153,000 miles. Have replaced a couple of alternaotors, a starter, and intake manifold gasket among other regular maintenance items. Car is still running strong.
I have a '95 / 3.1L with 160K. I have also replaced the alternator and intake maniflod gasket. Other than that, it has been a very good car.
Old 08-12-2004, 04:47 PM
lustofdecay lustofdecay is offline
Send a message via AIM to lustofdecay
'93 Lumina Euro 3.1 coupe. 94K miles on it, but ill be damned if someone rolled that bitch back a few hundred thousand miles on the odometer, at least thats what it runs like. not too bad, just starting it is a pain in the ass.
Old 09-10-2004, 12:17 PM
mikeslag mikeslag is offline
97 Lumina LS(not sure) 3.1 59,000 miles on it, just bought it, however and the service engine light keeps going on for a day then off for a day, and right before it turns off, I get a gust of hot air through the vents. Also it needs new coolant and I don't know how to change it. However I love the way it drives, and the engine is so so quiet. Please also look for my 2 other posts and reply to them if you like. would be awesome.
How many miles do you have on your TB ? Is your truck ticking ? gkelly455 TrailBlazer | Trailblazer EXT 5 05-26-2006 11:11 AM
How many miles did your Prelude go... NJMAXSELTD Prelude 5 01-01-2002 03:09 AM
How many miles does your G`s put on each year? Primera-TDLX General 13 09-14-2001 04:52 PM
