#16
Well, I decided a while back that I will be getting the "Sebring" fenders for Layla. And, for the record, the car you're thinking of is the MGC GTS, which actually was not a factory works car at Le Mans but in road rallies and at Sebring in 1967.
The works Le Mans MGB's were the infamous "droop snout" cars. I will go for Sebring fenders, a Costello hood, and probably ProperMG's rallye style air dam as far as appearance mods. If I go the crossflow route, I'll also work in the Moss Motorsports Roots Supercharger kit for MG's. 250-270hp in an MGB sounds like a good number.
Proud Owner/Operator of Haven Raceway and Hobby! |
#17
Re: Re: FF Drifters
Was that that dark blue one at steve's house? I knew I shoulda gotten that.
-Your Nitrous Makes Me Laugh- "I'm a firm believer in the philosophy of a ruling class." "Especially since I rule." ---Clerks--- "I am the NIGHTRIDER!! I'm a FUEL injected suicide MACHINE! I am the ROCKER! I am the ROLLER! I am the Out-Of-Controller!!!" ---Mad Max--- |
#18
Re: FF Drifters
I've got an 92 MX-3 GS it drift's almost anywhere in any weather.. and it's all stock... well with a 70f/30r weight ratio, and the majority of the brakepower is in the rear with no ABS *brakes aren't always needed* but I can drift my car pretty easily... can't hold it long, but that's because I use the load shift to drift not that handbrake (sidebrake) BS!
Current Car,: 1997 Mazda Miata bone stock. Sold: Mazda RX-7 TURBO II (blown apex seal) aka: Sara HKS F-CON, Defi Boost gauge, Greddy Ext. Temp Gauge, Greddy Blow off Valve Greddy S-type, full 2.5" exhaust system with Greddy Muffler, OBX Highflow resinator Sold: 92Mazda MX-3 GS, Tropical Green Metallic |
#19
Re: FF Drifters
HA HA thats sweet
#20
Re: FF Drifters
i tried it a couple times in my hatch but doesn't really work well...as far as drifting w/o using the e-brake....found it hard to loose traction in my rear tires....but i actually began to loose traction in my rear wheels once while taking a clover leaf type exit...was odd b/c it never happened b4 but it happened that time when i had a passenger...was odd was gonna try it again but i'm not one to try that type of stuff with a passenger on public roads
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
#21
Re: FF Drifters
i've tried a few times in my teg but i can't afford new tires so i stopped, i got pretty good at sliding around corners on some empty twisty road near my house though
#22
Re: Re: FF Drifters
Re: FF Drifters
no rubbin in my face, I can easly drift my MX-3 under the MX-3 forums I have my how to guide to drift my car, if any FF drifters want to check it out. There are many diffrent ways to get it to overstear, the method I describe has been the fastest method in my experence. I've personaly cut down on driftin because I've had to replace tires annualy for 2 years
, and I got other things to pay for so I've cut down myself, besides after this car is done I'm going to make a Renissis FC3S RX-7
#24
Re: FF Drifters
FF skid maybe? I don't know just an idea I had... its midnight, give me a break!
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
#25
Re: FF Drifters
Well...done tray under the rears w/ ebrake. 1 time i did "drift" when I had my escape I was driving my friends home, zoned out then realised my friend's street was coming up massed the brake and yanked the wheel car slid sideways but there was an on coming car so I massed the brake instead of the gas.
'04 WRX Stealth Wagon. SAE corected 225whp 230wtq Performance -M2 performance turbo back -kn air filter -Utec stage 2 base map Handling 17x7.5 ssr comps w/ RE730s whiteline front and rear swaybar w/ endlinks rear strut bar genaric brand ss brakelines sparco Speed w/ harness(soon to be 2 sparco pistas w/ harnessbar) |
#26
Re: Re: FF Drifters
RX-7 TII |
#27
Re: Re: Re: FF Drifters
#28
Re: FF Drifters
Well the way I drift is the Inertia Drift, also it'll be 3 to 5 years before I get the 7 so I'm sure by then someone would have gotten into a wreck with an RX-8 by then,and there will be more replacment parts for them by then, should be anyway....
