Old 03-29-2004, 09:15 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: What is the best motor for my hatchback?
you can't get an itr tranny to fit on a gsr engine can you?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-31-2004, 02:46 AM
SenseiAccord SenseiAccord is offline
Re: Re: Re: What is the best motor for my hatchback?
Originally Posted by projectsilvia97
O really, wow, that's interesting. cuz i just found these mounts, but they are probably custom because you said that, and you or so knowledgable.
http://hasport.com/shop/product_info.php?products_id=63
oh yea cuz the h22 was built and designed to be in a civic. if u go with a b-series swap for ur civic, u can save money from buying a H series motor mounts. You will also probably make life a lil more safer and make ur car lighter. You can also save gas since i think b-series use less gas haha. There is a reason why u dont see many cars with an H-series swap in a civic and more ppl using a b-series swap. I kno the H-series engine is pretty cheap on the markey but dont let the price fool u since it isnt an engine designed for ur car. I would just get the GSR swap.
Old 03-31-2004, 05:38 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i dunno about you guys...but i'd get the k20
Old 04-01-2004, 03:26 AM
is that the new RSX/Si motor? Those are pretty good. 160 hp right? dont kno much about them but since it is already in a civic... try go for em. 2.0 liter engine? got the displacement for torque.
Old 04-01-2004, 05:41 PM
SiGNAL748's Avatar
i'm talking about the jdm k20a (type-r)
220hp @ 8000
152 lb-ft @ 7000
basically the power of jdm h22 type-s, without the disadvantage of weight. Plus...you get 6 spd w/lsd
Old 04-01-2004, 11:55 PM
liquidflame8 liquidflame8 is offline
220hp @ 8000
152 lb-ft @ 7000
get one then. if you want to spend over 6k to have that motor be my guest. unnecessary in my eyes. if you were going to put over 6k into a motor it would be better to get a gsr and put 3k+ into it. unless you just want to be different or something. turboing the gsr would be a hell of a lot faster than the stock k20 type r motor
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
