| Latest | 0 Rplys |
#16 | ||
Re: Re: Alero coolant sludge problem
SCRT79, You sound like maybe you work for a dealer. What does the new gasket plus bolts cost? About the coolant swap you mention, is this a swap from Dex-Cool to green stuff? Also, in another post talking about the tire rub problem, it sounds like you are saying the dealer might replace for free. Is that true? Thanks, Mike |
#17 | |
The new bolts are nothing more than bolts with threadlocker on them. You don't have to buy the new bolts just make sure you clean yours very well and run them through on of those things that re thread bolts(couldn't think of the name of them) and then just put locktight on the bolts. You don't have to spend the money on new ones. Also check ebay for the gaskets I got the updated gaskets for $20 shipped to my door. Look to spend around $50 or more from the dealer and most parts places like autozone or pepboys don't have the updated gaskets. And the only difference between the old gaskets and the new ones is that there are two little metal cylinders by the bolt holes that prevent you from over torqueing the bolts and cracking the gaskets.
#18 | |
in CDN funds
#19 | |
p.s. yes i do work for a dealership
#20 | |
![]() Join Date: Mar 2004
On mine I used new head bolts that a must since the tourqe is dependant on this. As for the Intake bolts just wire wheel those off and make sure there good and clean. On mine I used red locktight and its working out verywell so far. Oh and as a rule I ALWAYS use felpro gaskets.
#21 | |
9 times out of 10 I'd use Felpro gaskets but they didn't have the updated version when I went to get the gaskets so I got the revised kit from GM off of ebay for $20
#22 | |
Wow I was in such a rush to get our montana done that I over looked the crush sleeves EEK. But I tourqued them down to specs and since its just the intake it shouldnt br half as bad as the heads were... Well almost. You are right though the felpro doesnt have them. I guess Ive blindley trusted felpro for to many years. Ill post if they go bad for some reason, but I do expect them to hold up! I hope!
Damien |
#23 | |
I hope you know when GM found out about the gasket constantly failing they released new torque specs. That was the reason they were all failing is because they were torqued too tight.
#24 | |
Yeah I used the new specs, but it did seem really loose feeling. Oh well I used locktight so they should hold fine. Like I siad ill post if they fail.
#25 | |
I don't recommend switching over the antifreeze to the green. If you use dexcool and distilled water you'll be fine. Why distilled? G.M. has a service bulletin out recommending it to reduce corrosion and sludge in the system.
#26 | |
jdeemer - I agree. I'm not planning to switch from orange DexCool, I've had it in several cars now, and have had no problems.
jamcllw - Can you tell me the updated gaskets' part number and if you've seen any still for sale on eBay? Also where can I find the new torque specs? What all am I looking at pulling off the top of the motor to get to the lower intake gasket? Thanks Guys, Mike |
