Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-02-2004, 09:41 AM
tomsmith tomsmith is offline
ok look this decision is up to you!!! look on the net and see what you think looks better even tho it is dumb to lower a 4x4 but people do lift 2 wheel drives just for the looks
Old 11-03-2004, 11:47 PM
Tafnar Tafnar is offline
I have a 88' 2wd lowered on Mk4 supra wheels. Its nice and clean. It has 3 inch blocks in the rear and beltech drop spindles in the front. I like the way it rides. Not bumpy and you can still feel the road. I have a rear sway bar off of a Grand National and got a bigger sway bar in the front from a old circle track truck. I have a Locker in the rear end also. Fun to go sliding around corners or doing doughnuts in some parking lots! On dry ground its a bit hard due to the 255/50/16s in the rear and the sticky Z rated tires that are wrapped on em.
Taco you want the 22RTE and your not looking to push the boost past 12psi your fine. The stock ECU shuts the fuel off to the motor after 12-13psi due to overboost. I had a 22RTE for a couple months. I pulled it out to do a tare down and rebuild it to take some high power with a SpeedPro standalone system because the stock ecu SUCKS, but I ran out of money.
I say, buy a SR20DET and take the valve cover to a machine shop and have them mill in TOYOTA and get rid of the NISSAN. Than tell everyone it used to be a 1JZ-GTE that you had 2cyls removed to make it a 4cyl. If you can make up a good story people will believe you. SR20s running stock can get up to 250ish by just cranking up the boost and playing with your timing. Then buy a AEM piggy back and bigger turbo and a alochol injection system (so you can run high boost but still run pump gas) and hit 350hp. They are very very common to find and for a good setup maybe 2-3k. Its a thought that I might do.
As far as the 4x4...LOWER IT!!! AWD baby, sleeper.
Here is my truck.
http://www.imagestation.com/picture/...3/fb42842a.jpg
http://www.imagestation.com/picture/...7/fb4968e1.jpg
http://www.imagestation.com/picture/...1/fb42842e.jpg
Old 02-22-2010, 09:18 PM
thatsright1369 thatsright1369 is offline
Re: toyota pickup should i lift or lower????
try the total chaos pre runner suspention and go up with it
Old 02-23-2010, 08:07 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
This thread is from 2004.
I'm thinking the OP has decided by now.
And welcome to AF !
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
2wd toyota pickup Goose69 Pick-Up 3 08-26-2009 03:27 PM
Lifting 1983 Toyota Pickup ebchinook05 Pick-Up 1 05-18-2007 10:45 AM
Lifted Toyota Pickup w/ 35" Swampers 9" lift custom grille, bars, lights, tint wheels maxaud Classifieds 0 06-13-2006 12:19 AM
Lower my Toyota Pickup 1bay95west0 Pick-Up 0 02-09-2006 03:07 PM
94 TOYOTA PICKUP needs some PICKUP! Thatguy858 Pick-Up 2 08-11-2004 02:40 AM
