Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 04-30-2005, 12:12 PM
ladyk325 ladyk325 is offline
Re: Tips for removing fuel filter
Sorry to get off topic but does the 2000 Malibu have one or two fuel filters? I've been told that it has two but I'm only finding one. Does anyone know?
Old 07-23-2005, 08:54 PM
RalphT RalphT is offline
Originally Posted by galantin
ok if you have or had the black plastic quick connect heres what you do, if you still have the black plastic on the quik-connect side do this: get a pair of needle nose pliers and gasp the filter between the quik-connect and the filter body, push the hose into the filter as if you were putting it back on and hold it, then pry up with the needle nose pushing the black plastic into the line away from the filter, keeping pressure on the the black plastic pull the line away from the filter. thats it, if you have ever used a quik disconnect tool it is the same way but it is built in the line. use the pliers only to push the black plastic up not to actually grasp it.
I have a green piece of plastic in the way. Do I need to remove the green piece of plastic first? It looks like it wraps around the black connector. Thanks
Old 07-24-2005, 08:11 PM
galantin galantin is offline
no the green plastic is opened with a small screwdriver and then you push it in so it pops out the other side a little and thenpull it away from the filter. re-install the filter and then close the little latch
Old 07-24-2005, 09:44 PM
Oh..duh sounds very easy. Thanks a bunch
Fuel Economy Tips for a Jeep Wrangler 2009? wranglewithmyjeep Cars in General 0 01-13-2011 08:13 PM
Hammer Out My Fuel Filter CallBob Jimmy 1 09-07-2010 07:42 PM
Tips on Changing Fuel Filter freesiagirl Metro 6 08-25-2007 11:58 AM
Tips for Changing Oil Filter? camrycurt Taurus | Taurus Wagon 14 07-02-2006 06:23 AM
