Old 03-09-2004, 01:18 PM
91civicDXdude's Avatar
Re: question
your DX cut out at 6800 rpm. your tachometer was off. there is no variation in ROM programming in honda ECUs. it is hard coded as one variable and one variable only.
Also, on a compression test, to get more accurate results, remove the fuel pump fuse and hold the accelerator to the floor. this is so the throttle stays open and more air gets in so the test doesnt take as long and will be more accurate to real conditions. make sure the engine is warm also.
Old 03-09-2004, 01:32 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: question
88-91DX
88-91LX D15B2 1493cc
4 cyl, 16valve
SOHC
9.2:1 c.r
92 bhp @ 6000
Redline: 6800 rpm
89 lb-ft @ 4500
88-91Si D16A6 1590cc
4 cyl, 16valve
SOHC
9.1:1 c.r.
108 bhp @ 6000
Redline: 7100 rpm
100 lb-ft @ 5000
That information was taken directly from 4thgenerationcivic.com.
There IS a difference between the si and the dx. Also, redline is different than the fuel cut off. My car redlines at 7100 and cuts off at 7500. My dx used to redline at 6800 and cut off at or around 7200.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-09-2004, 01:36 PM
Re: question
again, you are wrong sir.
the DX ECU PM5 has a fuel cut set in the ECU's memory @ 6800 rpm. the "redline" is only the red line on the tach, which is 6500 for all models except for HF that have a factory tachometer.
the Si 90-91 PM6 ECU has a fuel cut @ 7414 rpm, but most often times is represented by 7200 rpm on the factory tachometer.
this was taken from the good folks @ pgmfi.org, reverse engineering honda ECU's tends to tell you the actual value, not something somebody heard or read on a website.
by saying there is no variation in honda rom's, i meant per ECU. all PM5 ECU's are identical etc.
Old 03-10-2004, 11:50 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
so are u guys thinking its my ecu then? as for the compression, test what am i lookin for, and say its not right, what does that mean? thanks for all ur help guys!
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 03-11-2004, 12:27 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
If the tests were low, you would most likely benefit a lot from a set of piston rings and may even find out that you have a bad piston. Or you could do a leakdown test, It tells you a lot about your engine actually. Shows if you have bad valve seals, head gasket, and/or rings, look into it...
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-11-2004, 05:25 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Re: question
Yeop my car is one that cuts off at 7414...almost up to 7500.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 03-12-2004, 12:28 AM
outofstep's Avatar
Re: question
well its a new motor, and they claimed a leakdown test was done. i believe i mean dont get me wrong the car is quick like once its going its fast it just seems to bog on on tourqe
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 03-14-2004, 12:13 PM
outofstep's Avatar
Re: question
has anyone else done this swap, what ecu did u go with and what do u think about this motor compared to an si motor
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 03-14-2004, 10:11 PM
erastusboy erastusboy is offline
Send a message via AIM to erastusboy
i thought the d15's were the 64 hp engines in the hfs im so confused now
Old 03-14-2004, 10:15 PM
Re: question
d15b2 is the engine that is in dx and lx cars which is 92hp...and i think d15b1(???) is the one in the hf. If u check up under the frequently asked questions thread at the top i think it has all that stuff in there.
bwhahahaha
Old 03-14-2004, 10:44 PM
outofstep's Avatar
Re: question
d15b is a jdm civic vti motor sohc vtec
i changed the fuel filter today since it been a while, but that didnt really do much. i was reading up on it and i think it may have 2 vtec switches... i have one hooked up to my vafc2, perhaps the 2nd isnt hookups up, yo kris where u at ur a pro with this swap
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 03-15-2004, 04:05 PM
outofstep's Avatar
Re: question
http://asia.vtec.net/article/d15b/
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 03-15-2004, 04:37 PM
outofstep's Avatar
Re: question
hasnt anyone on this forum ran this swap besides me???
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 03-15-2004, 05:54 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
What are the specs on the jdm d15b? Are they as good as the Si bottom end?? I'd almost say that's what's holding you back - the Si bottom end has more torque, - your both running intake header and exhaust with Si ECU. I don't know if the vtec head would give you that much more advantage on the 1.5l block compared to his 1.6l block. But I don't know the specs on the jdm d15b either - I'm prolly thinking the the stock d15b2 with 92 horse.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-15-2004, 06:09 PM
Re: question
Looking at the 4th gen FAQ sticky thread it says the jdm d15 has 125-130hp.
bwhahahaha
Questions,Questions,Questions.... r_c_inicial Mustang Talk 11 08-23-2005 08:26 PM
Questions Questions and more Questions H22silverbullet Prelude 15 07-30-2005 07:23 PM
Question Question Question Integra14 Car Modeling 2 12-07-2002 08:31 AM
