#16
Re: motor mounts and struts on 95 Camry
peter1 - As I said in response to your other post on exactly the same subject:
In addition to the FR mount and dogbone, there are two other mounts. There is a RR mount around the same place as the FR mount, only on the side next to the firewall, and there is also a LH mount, under the transmission. Maybe you have to loosen the other mount. Last edited by Brian R.; 08-12-2004 at 03:56 PM. |
#17
the rear mount is not a problem for you unless your tranny rattles. Since you've already replaced 2 mounts, try replacing the drive side axle and that should eliminate all your vibration.
#18
does drive side = drivers side?
Thanks Peter1 |
#19
yes, driveside equals driver side
#20
Re: still at it
After 1 hour of trying to get the top bolt on the rear motor mount I used a 17mm Crow Foot wrench from the top with 2 extensions to get down past the manifold. It took 5 seconds to loosen nit once I went to Sears to buy the wremch.
Re: Re: motor mounts and struts on 95 Camry
Thank you for the details on the change out to the front mount of the 95 Camry. I had no problem following your directions. As a novice like myself, I was not sure why they included a double stud on the top of the new motor mount, but I figured out that they wanted me to use this to insure that I had the mount positoined before I locked down the bottom bolts. I let the engine down slowly on the motor mount and the roll pin popped into place, then I unscrewed the double chaser stud and inserted the top bolt. Only problem I had was that the bolt that mounted from the bottom seemed to strip at the last turn of the wrench, so I think that I did not have it started correctly, but the other two bolts are holding it just fine. Maybe I should have let the engine down completely and firmed up the two top bolts before trying to position the bottom one..... Oh well.... Again.. thanks for your details Jenny |
