Old 01-04-2002, 10:20 PM
Dahmin8's Avatar
Dahmin8 Dahmin8 is offline
If you have gotten as far as you say then I was incorrect about the hub separating from the knuckle with the 4 Torx bolts. You will have to remove the whole assembly from the upper control arm and the 2 lower ball joints. A tuning fork shaped chisel will be needed to do the job of separating the ball joints from the knuckle. Once completely detached form the car you will need a press, as you believed.
Sorry about the bad info. I was doing this from memory and I currently can't find that Chiltons' manual.YES YOU NEED A PRESS
I have slotted rotors for a reason. Of the three or four types ie; cross drilled/slotted, slotted, cross drilled I could afford the slotted ones. I am not not which of theses runs the coolest but they all operate in a cooler range than stock. Each has it's advantages and disadvantages.
Dahmin8 90 Accord LX
Old 01-05-2002, 01:04 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
actually i used the book and they did not mention anything about the press. all they said was that the hub should come out after unscrewing the 4 thorx screws in the back. Well i'll take it apart tommorow and see what i can do. i'll take it to a shop.
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 01-05-2002, 10:53 AM
Dahmin8's Avatar
You are right if I remember correctly the manual doesn't specifically say press the hub apart. This is the reason that most people take a job like this to a professional. "INCOMPLETE INSTRUCTIONS" Good luck on your install.
Old 01-05-2002, 11:12 AM
you know for this reson i took the book back to the store and i got a Haynes for 90-93 accord wich sucks even more. Maybe i'll get the Chiltons with the yellow lude again. It was by far more superior than tne Haynes.
Haynes Sucks Big time !!!!!!
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 01-05-2002, 11:26 AM
Dahmin8's Avatar
That's holarious.:frog:
need more brakes and grip.... proud_924s_owner Focus | C Max 0 01-23-2006 10:24 AM
Suburban Brake Blues GMCblues General Discussion 1 11-08-2004 11:54 AM
Why rear rim got more brake dust? eohrnberger 924/944/968 4 11-01-2004 01:04 PM
More brake problems brainleak Alero 12 10-11-2004 08:10 PM
