Old 02-12-2004, 03:54 PM
93hybridaccord 93hybridaccord is offline
Any update on the sound yet?
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 02-12-2004, 08:23 PM
Accord Girl Accord Girl is offline
Question Re: 93 Accord - Unfamiliar Engine Noise
Thanks for the pic.
The noise is NOT coming from the alternator, Distributor, or the wheel hub bearing. The noise source is somwhere below the Engine.
I couldn't get to pin-point the exact location..Its to the right of the circle (in the pic above) and under (?!)
Can you help...
Thanks
Old 02-13-2004, 02:31 AM
Re: Re: 93 Accord - Unfamiliar Engine Noise
Originally Posted by Accord Girl
Thanks for the pic.
Can you help...
Thanks
Is it kind of a squeeling sound?
Old 02-13-2004, 09:01 AM
Re: Re: Re: 93 Accord - Unfamiliar Engine Noise
It like parts rubbing. I am not sure if its metal. There are others that said it sounded like plastic (metal rubbing a plastic part).
It sounds like pebbles inside a tin can....
Old 02-13-2004, 09:12 AM
ProMan ProMan is offline
Re: Re: Re: Re: 93 Accord - Unfamiliar Engine Noise
Water pump bearing???
Old 02-13-2004, 12:57 PM
Does the car run fine other than the sound or can you feel a difference in performance?
Old 02-13-2004, 05:14 PM
The car runs just fine...
Water pump - Does a defect here generate that noise? Should the pump be replaced or is it the bearing?
Thanks again
Old 02-13-2004, 09:05 PM
I didn't hear your noise. Just guess from "pebbles inside a tin can", sounds like a bearing issue.
The waterpump and bearing is one piece.
Old 02-14-2004, 05:54 AM
A failed bearing usually sounds like a squeeking noise, not like pebbles in a tin can. Bearings heat up and melt and usually fuse themselves to the casing around them causing a metal to metal sound. Man this is tough, it's difficult not hearing the sound. You say it sounds like it's below the engine? Are you sure it's just not coming from inside the engine itself. The only thing I can think of that kind of sounds like pebbles in a tin can is maybe a valve knocking.
Old 02-14-2004, 10:28 AM
might be a little off track.
Can this be a problem with the exhaust? Cat converter......(??)
Old 02-14-2004, 04:10 PM
Without listening to the noise, it's very hard to tell what it might be. Could be something loose also.
Old 02-14-2004, 08:53 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
I have another guess.... it could possibly be either the catalytic converter or the shield. Our van was making the "pebbles in a tin can" noise, and it was pronounced at idle and during acceleration. what our problem was the shield was loose, hope this helps.
Old 02-14-2004, 09:50 PM
Thanks very much guys. Appreciate it.
I will have this checked and replaced....sometime later probably. And update the result as well...
Old 08-29-2004, 07:03 PM
Hello again,
The 'pebbles in a tin can' noise turned out to be timing belt tensioner. I replaced all the belts that go with Timing Belt + Water Pump (now poorer by $800).
Also changed the exhuast system (except the Cat converter.)
Thanks again for all the help!
Any advice / suggestions on removing some rust spots?
Old 08-31-2004, 12:52 AM
accordztech accordztech is offline
Send a message via AIM to accordztech
good job.
come to www.cb7tuner.com for more accord problems etc...its our community....
hit me up on AIM if u ever need anything.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
