Old 01-22-2004, 01:11 AM
ellets ellets is offline
starter
Just had to put a new starter on my k-20 .83mod. I was breaking nose cones about every 4or5 months. Newest one I got had a totally different nose cone and was a geared starter with a much smaller body.
It fit and workes fine.
Old 01-22-2004, 01:22 AM
acgr76 acgr76 is offline
Send a message via MSN to acgr76
Re: starter problems
i installed a single 1/8 shim on the outer hole of the starter and it works perfect, for now...
Old 01-22-2004, 01:36 AM
comp comp is offline
one of the main resons for broken nose cone's is coming loose, and kick
back from engine(not that often) check those bolts!!!!! the smaller
gear reduction starters don't hang on the bolts as bad,, the pain in the
butt bracket on the end of the starter can help
Old 01-23-2004, 03:22 AM
thanks !!
Old 02-21-2004, 04:39 PM
Dead again!!i just heard an explosion when i was starting it.... one more question and attempt, dont know what to buy, the dashboard says SCOTTSDALE that is chevrolet, but the VIN appears as a K1500 that is a GMC assembled in canada is there a diference in GMC-CHEVROLET, USA-CANADA, starters? i buy in autozone so they are very specific...
Old 02-21-2004, 04:59 PM
are you breaking the nosecone?????
Old 02-21-2004, 05:10 PM
not this time but have broken 2
Old 02-21-2004, 05:32 PM
you need to start from scratch!!!!!!!!!! use a tap to clean threads, are
they worn out, your bolts have been in and out more than 3 cars...
also find and buy the starter brace, it helps take the strain off after you
get it shimmed correctly i would use some loctite on the NEW bolts
Old 02-21-2004, 05:53 PM
what replacements should i use gmc/chevrolet usa/canada?
Old 03-01-2004, 11:01 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Re: Re: starter problems
As for the c/k. C stands for Chevrolet, K stands for GMC
C is code for 2 wheel drive
K is code for 4 wheel drive
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 03-03-2004, 12:55 PM
Dominick Dominick is offline
I think you will find that C is the two wheel drive and K is the four wheel drive and not Chevrolet or GMC identification.
