Old 01-07-2004, 10:55 AM
Magik Si's Avatar
Magik Si Magik Si is offline
Re: Re: First Engine Pull...
Originally Posted by kris
Check all your vacuum lines for the idle surge, chances are, thats the problem. If they are all correct, then your EACV valve is not liking your new setup.
It did it "before" I changed engine's too...then stopped...so I have no idea...someone suggested that my IAC was dirty...but I have no idea where or what, that is...or how to clean it...and Honda tells me a new one is $240.00...but man it's really irritating...and I don't want anything else to break because of it...
Jason
PS> Honda also suggested that the throttle cable was too tight???
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 01-10-2004, 06:47 PM
Magik Si's Avatar
So today I installed a new radiator, new valve cover gasket, new spark plug seals, new spark plugs, new pcv valve, and a cold air intake...the only problem is with the CAI (I started a thread about that)...
The pcv valve was to solve an idle problem (which is what Honda told me was the problem) I'm having, it is revving from about 900rpm-2000rpm repeatedly over & over...the pcv valve didn't solve the problem...what else could it be???
Jason
