#16
Re: Re: Help me decide...
.Quote:
The main thing that causes problems is that people use the wrong size drill bit to drill the dowel pin hole. It requires a 14mm drill bit but most people use a 9/16" b/c it is close but it allows the head to move around and not get properly aligned. Also people over look the rotating assembly on the LS you need to install a girddle on the main caps to keep everything together. Also people doing a shitty job on the oil line tap etc the list can get longer. Here is a website for you to check out. www.c-speedracing.com/howto/b20vtec/b20vtec.php
Re: Re: Re: Help me decide...
See, there it is. And from one of the more experienced and knowledgable members just like I said.
#18
Whtteg - I saw the post about the dowel adaptors for an LS/VTEC by golden eagle and I believe they also make a conversions kit for the oil supply as well, do you have any expirence with these or know anyone how does. These seem to be a good fix to the two biggest problems you mentioned. Thanks for your help.
DoubleTap |
#19
Re: Re: Re: Re: Help me decide...
Re: Re: Re: Re: Re: Help me decide...
Sorry, I didnt mean to say what you said, when I started no one had replied. I must be slow
#23
Boost It Or Buy A B18c5 ,jdm Type R
#24
Just about figured it out...
All the info has been great. That link to the vtec swap was very informative.
I think I'm going to go for the frankenstein. Maybe even upgrade some internals while I'm at it. That is where I'm gonna start. I'm sure that will keep me happy for a little while. At least until I get the itch to turbo it. ![]() Someone suggest something besides ebay for getting the parts. Thanks |
#25
thepartstraderonline is decent. People can be stingy though and you have to be even more careful in dealing with these people because its a lot easier to get ripped off. And if you get find a hot deal, chances are.. it is hot.
#26
with 5 grand you would be able to build up a real nice N/A setup ofcourse turbo will be the fastest though.
#27
Try to find a local board inyour area for imports and post a want to buy list there. Like here we have vtecatlanta.com and people buy and sell stuff there all the time and you can just meet the person and pick it up. It is the safest way, but www.thepartstrader.com is a goodplace but liek spectre said be careful people can rip you off. Use paypal and hope for the best, don't ever send a money order or a check.
you should boost it cuz those motors LOVE BOOST, on stock internals they can handle 13 lbs of boost, and with hondata and a very unrestrictive exhaust you shood b runnin 12's if not better.
#29
The folks who know - So the LS/Vtec sounds like a good way to go for me as well. Well i have a few questions about the specs on a properly assembled LS/Vtec with stock internals. Does it get the GSR redline at like 7800 ar the LS redline at about 6800? Do you know how well they work with a turbo? I assume they can still take the 10-12psi as the LS becuase that is more of a factor of how strong the block is and not the head (right?). Anyody know what a "stock" LS/Vtec puses at the wheels (or at the flywheel). Thats all I can think of for right now but I will probably think of some more. I'll try to read the forums before I make and extraneous posts though. DoubleTap |
#30
i would go ls turbo screw the vtec
if you look at the pro. turbo drag honda's they arnt vtec for a reason |
