Old 10-07-2003, 04:37 AM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
If you really want to keep the Auto go with an aftermarket torque converter, expensive though.
MY CAR!
Old 02-02-2005, 10:07 AM
autoenthus3 autoenthus3 is offline
Send a message via AIM to autoenthus3
It's two things.. like the he said its the power loss from the drivetrain and its the gearing. Most automotic transmissions are either 3 or 4 spds with OD. And the more gears you have... the less power loss you have because when you shift its going to be at higher rpms already. And its deffinately not when it shifts because you could put it in D1,D2,D3 and D and shift for it.... basically the same thing that drag cars do except a little better with a rachet shifter. They only need 3 gears
Old 02-03-2005, 09:08 AM
polacek's Avatar
polacek polacek is offline
Re: auto to manual conv
Could this be a record? Almost 2 1/2 year old post.
Old 02-18-2005, 01:14 AM
tegra92 tegra92 is offline
is it severely difficult to do a tranny swap on your own and if not where can i get info on how to do it?
Old 04-14-2005, 06:00 AM
civicson234 civicson234 is offline
help
I have a 95 hatchback dx. I found someone who is selling a b16 out of a 93 Sir-II(i am in england after all, and they have jdm cars here) Currently i have an automatic transmission in the car, and i want to keep it that way, but i dont know if the swapped engine will bolt right up to the transmission. Ive looked into this on the internet and i casnt find any information on this. Hopefull this thread is still active and someone knows what i can do.
Old 04-19-2005, 12:01 AM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
Originally Posted by craz_e_99
piscorpio left out:
1)Place Racing Tranny mount---regular 5spd mount wont work becuz chasis is slightly different (placeracing.com---they are the only ones who carry this mount at this time--$152)
2)Front tranny bracket---manual has 3 holes for tranny, auto mount only has 2 in different spots
3)Rear tranny mount is a myth---not necessary, auto mount is fine
4)Tranny bolts
5)Flywheel bolts
6)Flywheel cover---not exactly necessary but nice to have--i dont
7)Shift linkage bolts---not just the rods, u need the cup and rear mount and rubber weather seals and u have to drill the holes for rear SL mount
8)the console ring for shift boot to keep it in place---i dont have it yet so my shift boot is just there
9)plenty of other miscellaneous bolts and nuts
if u have no clue how to do this or how things work together, you might wanna take a trip to honda and get alot of diagrams for things....
Ummmm what about axles?......
Old 04-20-2005, 02:06 AM
fasthatchb18c1 fasthatchb18c1 is offline
LOL i dont think your gona get a reply considering this post started years ago and civicson you wont be able to but a D series tranny on a B16
Old 05-23-2006, 03:39 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
Re: help
D series engine will not bolt up to a B series tranny, won't work. However, if you just wanted to keep an automatic transmission for some odd reason, there were B16 that came with an auto trans. Look for one and you may have your solution. Personally, I wouldn't opt for the auto over manual.
Hows that for proving fasthatchb18c1 wrong!?
Come back in a year, and I will post again.
Old 05-23-2006, 11:09 PM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
1997 Integra GSR and 1992 Civic LX
Old 05-24-2006, 12:33 AM
polacek's Avatar
I am willing to bet the guy no longer has the car! 4 1/2 years later, Xnoitareng only has 6 posts. He's outta here.
Manual vs auto yazzagaffix Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-15-2009 05:45 PM
Prelude JDM H22A swap/manual conv. problems cherrobrob Let's get Technical! 0 03-05-2004 09:45 AM
Auto 2 Manual Conv. <[4gen91CvcLX]> '88 - '91 Civic | CRX | Wagon | Shuttlee 6 06-30-2003 03:35 PM
Auto-Manual Parts locating I need your help SFF900 Engineering/ Technical 0 02-18-2002 05:14 PM
auto-manual conversion? Shobo Engine 10 07-31-2001 05:00 PM
