Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-07-2004, 01:24 PM
bustedratchet bustedratchet is offline
Re: Re: Re: Re: Re: passenger climate control
That is weird I try to find some info to see if the HVAC can be reset.
Old 01-08-2004, 08:02 PM
Re: Re: Re: Re: Re: Re: passenger climate control
Jim I looked at a flowchart and it said first to check for a broken or loose arm that operates the passenger side temp. Also I saw that if the programmer was to be changed that it could be reset by leaving the key in the on position for 3 minutes.(Without engine running.)
Old 01-08-2004, 10:12 PM
jim56's Avatar
jim56 jim56 is offline
Re: Re: Re: Re: Re: Re: Re: passenger climate control
Ok... I'll check and try that this weekend... If that doesnt fix it, I'll
get you an exact temp differential between the two sides.. just FYI
Old 01-08-2004, 10:13 PM
jim56's Avatar
Does it matter where the temp controls are at while you are re-setting it?
Old 01-09-2004, 06:15 PM
Re: Re: Re: Re: Re: Re: Re: Re: passenger climate control
For the reset, no it doesn't matter. This is for a new programmer It's worth a shot.
