Old 01-23-2002, 07:15 AM
Tireburner's Avatar
Tireburner Tireburner is offline
Door locks are in the harness exiting the drivers door. It is a pretty big harness. On some trim levels the harness comes into the body of the vehicle and goes straight up, making access very hard. On those vehicles I pull back the rubber boot that runs between the door and the body of the vehicle, tag my wires there, and drop them into the vehicle. Otherwise you can go to the door lock timer, which should be behind the glove box on the right hand side.
Old 01-26-2003, 09:59 PM
Dark Ne0 Dark Ne0 is offline
My '93 eclipse 5-speed needs the clutch depressed to start, will i need to bypass that by myself to install a remote starter or do remote starters come with special wiring for that?
Old 01-27-2003, 02:56 AM
ales's Avatar
ales ales is offline
Forza Schumacher
If you are planning to install the remote starter by yourself, bypassing the clutch switch should be of no problem whatsoever.
Old 01-28-2003, 11:36 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Be sure to put it on a switch b/c some cruse control systems cut off when the clutch switch is triggered. It will also help you to remember to leave it in neutral.
Old 02-10-2003, 11:46 AM
72DEMOLITION 72DEMOLITION is offline
i kNOW
I WORK AT A DEALER THAT INSTALLS AUTO STARTS wE USE THE COMPUSTAR I'M NOT SURE OF A WEBSITE ON THEM BUT THERE IS ONE THEY OFFER A KIT FOR MANUALS ALL YOU HAVE TO DO IS WIRE UP A FEW MORE THINGS LIKE A BRAKE INPUT SENSOR. tHEY HAVE YOU CUT A GREEN WIRE IN THE COMPUTER THAT COMES WITH IT TO GO FROM AN AUTO TO A MANUAL. IF YOU HAVE THE MANUAL THE WIRE DOES NOT GET CUT CHECK UP ON IT THE NAME IS COMPUSTAR:sun:
72 DEMOLITION
Old 02-22-2003, 07:38 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
Guy's if you do this please be carefull!!! I'll tell you a story.
I work at a Chevrolet Dealer, customer drops off his 95 Z28 6 spd. Has a remote starter hooked up through his factory keyless entry and never made any mention of it to our service department. Technician goes to get the car hits the unlock button, the car starts up and takes off across the parking lot hitting 4 other customer cars, 2 NEW Corvettes and 5 Cavaliers before it finally comes to rest. Forgot to mention that it also hit our lot porter. So needless to say there is all this damage and who is to blame?
Customer is in deep poop because his system had the disclaimer about the manual trans, he didnt notify anyone and now he is in ine of the biggest lawsuits I've ever seen here.
So please, if you do this not only be carefull yourselves but please make sure everyone who ever may come in contact ie. service departments, body shops, friends, whomever is aware it has been installed.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-22-2003, 07:42 AM
whtteg's Avatar
I agree good advice!
Old 02-22-2003, 08:24 PM
454Casull 454Casull is offline
Re: i kNOW
Is your Caps Lock key broken? That's the third post of yours I've seen like that.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 02-22-2003, 09:49 PM
whtteg's Avatar
Re: Re: i kNOW
