Old 11-09-2003, 01:50 AM
hairy30 hairy30 is offline
well i'v about had enough of this damn chevy p.o.s and i am now given up on it and am taking it to a dealership . thanks for all your input, and if i need it again or if anybody needs any thing useful from me i'm here. thanks for everything!!
Old 11-09-2003, 10:51 AM
TopDogg TopDogg is offline
After you get your truck back from the dealer and PAY them find out what the problem was then go home and call around to local service stations/garages and see what someone else would have charged. If you are to embarrassed afterwards to let us know I think we will all understand.
Old 11-15-2003, 08:26 PM
Carl C Carl C is offline
Re: 92' S10 Problems:
Check your block temp sensor. It caused mine to do the very same thing. The TBI goes into full choke mode and you can barely get the truck to limp along. The cat gets cherry red as well from all the un burnt fuel in the exhaust.
I replced a shit load of stuff before putting it on a Diacom unit my brother had and finding the $4.00 temp sensor was saying the block was -400 degrees. The computer than put itself into full choke mode so that it would cold weather start and was waiting for the block temp to rise. Of course the bad sensor never lets that happen so there you are getting about 1 mile per gallon and a truck that can only limp along choked to death with fuel.
Hope this helps,
Carl
Old 11-16-2003, 10:59 PM
dirt49er dirt49er is offline
check the fuel lines and see if all that shit from the two stroke plugged it up, also check the fuel filter to see if its clogged, because when u step on the gas if it runs like shit then its not getting enough fuel. even if you checked the fuel pressure, its not saying how much it can pump. also replace the fuel pump.
Old 11-17-2003, 11:50 AM
kingmac12 kingmac12 is offline
check your muffler to see if its full of junk from the converter
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
97 Chevy s10 miss under load metalman55 Problem Diagnosis 31 05-11-2015 10:19 PM
2003 s10 transmission problems burk4200 Problem Diagnosis 6 03-30-2009 07:07 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
350 in 92' S10 Blazer? Hurst25 Blazer 3 02-13-2004 04:56 PM
