Go Back   Automotive Forums Car Chat > Dodge > General Discussion
View Poll Results: Is this possible for a daytona 89.
Smart? 1 33.33%
Originality. 1 33.33%
Never going to work. 0 0%
Add More? 3 100.00%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 10-31-2003, 04:58 PM
PWMAN's Avatar
PWMAN PWMAN is offline
I think he just meant to say ECU, meaning the computer. Just a typo.
Old 11-01-2003, 12:08 AM
Bazilisck311's Avatar
Bazilisck311 Bazilisck311 is offline
Send a message via Yahoo to Bazilisck311
ok, so ECU=engine computer, thought i would have to change that
Old 11-01-2003, 07:24 AM
PWMAN's Avatar
I think it stands for Electronic Control Unit.
Old 11-01-2003, 02:59 PM
whats that? another name for the engine computer?
Old 11-01-2003, 04:28 PM
86shelby_charger's Avatar
86shelby_charger 86shelby_charger is offline
Send a message via MSN to 86shelby_charger
sorry... that was a typo... I ment ecu. As foar as the Tranny goes it was the same as the tbi and turbo 1 and turbo 2's from 87-90 .the only one that was different was the turbo IV wich had stronger components, but the same ratios.
Old 11-02-2003, 12:52 PM
PWMAN's Avatar
Re: Daytona 89 modification
Actually, 87-89 TBI's and T1's got the A520. T2's got the A555. 89 TIV got the small spline A568. In 1990, all tranny's were large spline. TBI's and T1's got the A523, T2's and T4's got the A568 large spline. Same with the T3.
The 555 and 568 were made by Getrag of Germany and had extremely strong components.
The 520 and 555 did NOT have the same ratios at all. Neither did the 523 and 568, all different.
Old 11-02-2003, 02:16 PM
Sorry, pwman's right...I just found all the stats, There are ways around the different sized splines though, and all the transmisssions have been used on the turba cars at one point. In any case, the one in oyur car should be able to do the job no problem, The only thing you should do is get rid of the long drive axle on the passanger side and replace it with the 2 shaft disign, it helps with the torque steer. Theres a really good transmission guide at http://www.thedodgegarage.com/trans_guide.html He tells u what transmissions were used for what years and what vehicles..
Old 11-02-2003, 02:31 PM
PWMAN's Avatar
[quote=86shelby_charger]The only thing you should do is get rid of the long drive axle on the passanger side and replace it with the 2 shaft disign, it helps with the torque steer. QUOTE]
Old 11-04-2003, 10:10 PM
lol, ya all do realize daytonas dont have transmissions right? they have transaxles ecu = emissions control unit right? I dont have to replace the engine computer?
Old 11-04-2003, 10:13 PM
ecu= engine contol unit it controls fuel flow, air fuel mixtue, that sort of thing, transmissions...transaxles....same crap...different pile!!
If you can't hear it coming....Why bother!!!
Old 11-04-2003, 10:19 PM
so the ecu is the engine computer, alrighty. got me list now
Old 11-04-2003, 11:48 PM
u need to add 1 more thing to your list, the underhood wiring harness, sorry, forgot about that 1.
1)underdash wiring kit
2)ECU
3)Vacume lines and plumbing
4)Turbo engine
5)under hood wiring
6)power module
7)solinoids
yeah, thats it!!
the best thing to do is get a "donor car" Then it's a matter of putting all the parts from the donor car in the same place in your car, that way you have a real life visual guide!!!
Old 11-05-2003, 03:51 PM
yeah i got a donor car, just without an engine, lol im gonna buy the engine from the factory, bout 1,500 bucks.. other than that, everything seems intact, although i should probably get a carfax report, jes to make sure
thanx a bunch
now, all i gotta do is get the current engine running good until i have the down time to make the swap
Old 11-05-2003, 03:59 PM
are u sure u don't have to buy the turbo seperatly? that sounds awfully cheap!
Old 11-05-2003, 04:13 PM
the car was free it was a bout to get crushed, so i was like NOOOOOOOOOOO!!! i took it off of him. nope, not sure of anything until i start making the swap, ill probably have to buy brand new everything, there is a reason he wanted it crushed but like you said, i can use it as a guide
Car Body Modifications Beetleman General Issues 1 02-22-2009 03:28 PM
1986 N/A Daytona to a turbo 2 Daytona KingFiasco General Discussion 5 07-27-2003 01:10 PM
