Old 01-16-2004, 07:30 AM
DTalon DTalon is offline
Re: Help! Wheels locked up?
dales:
Well the car has 167 thousand Kilometers, n i kno 4 a fact im at least the 3rd or 4th owner i suspect the car has bin driven hard, the wheels seem to be worn down on the drivers side only....ive never driven it myself yet béc i juss purchased it, im not sure if it burns oil or not id have 2 get it started 1st,,,,a mechanic in my family suggested i try to manually crank it 2 c if it turns this will tell me if it did any damage 2 the valves.
The car is a turbo front wheel drive, so i prett much assume its bin driven hard n the las owner juss gave up wit putting money into it.
Dom
Old 01-16-2004, 01:00 PM
MrZ's Avatar
MrZ MrZ is offline
DTalon;
Based on the mileage and on the assumption the car has been driven hard, my opinion is that you really need to pull that motor and have it gone over by a good shop. I say gone over, because you don't necessarily have to go into it expecting a full rebuild. It is possible that your crank journals are good, and maybe even the bearings on the bottom end are still ok, but you don't know that until you look at it and measure it all up. I always recommend this work be done by a good shop, they have the tools and the experience. You can pretty much count on having the cylinders honed, maybe bored, new rings, wrist pins, etc. Again, you won't know exactly what you'll need until you get it all measured up and checked. It goes without saying that the head should be done if you're doing the bottom end.
I don't know what your financial situation is like, but it is worth the investment to have the work done. You definitely want to have a strong foundation to build on, the last thing you want to do is restore power to a tired bottom and top end, and end up throwing a rod, or spinning a bearing, etc. Not only would that be expensive, but I actually had this happen to me many, many years ago (I threw a rod) while racing someone, and damn is that humiliating! The other guy was laughing his ass off!
Mark
HUGE Wheel Lock nut issue! Need help finding the right key/socket to fit! Passatguy Tires and Wheels 4 08-31-2010 11:46 PM
Wheel locked-up while driving dag77423 Wrangler 3 01-30-2006 11:44 AM
Rear wheel lock up 1999 Ranger? mikebike Ranger | Courier 4 01-07-2005 08:20 AM
2000 Expedition wheels locked up mdg01 Expedition 1 10-19-2004 06:58 AM
One wheel locking up Spyder81 Wrangler 1 06-29-2004 02:38 PM
