Old 09-08-2003, 11:28 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Re: Anyone every tried a Sharpie Marker for Window Frames?
Originally Posted by freakray
I tried it, it sucked, I won't do it again.
I couldn't get a satisfactory coverage with a Sharpie, fortunately I was trying it on a scrap clear part.
If you read back through the posts, you'll see that it is NOT recommended for clear window surrounds. This technique is for window frames only.
If you do make a mistake or it doesn't come out right the first time, rubbing alcohol will usually remove the marker. This is also why I use BMF as described above. It protects the surrounding area from slip-ups.
I should also add that adding a coat of clear flat, semi-gloss or gloss can control the purple-ish hue.
Also, make sure that you use a new marker. The flow of the ink is better and you end up with better results.
Old 09-08-2003, 12:02 PM
blueboost's Avatar
blueboost blueboost is offline
Re: Re: Anyone every tried a Sharpie Marker for Window Frames?
Preach on brotha!
Old 09-08-2003, 12:42 PM
Lambo003's Avatar
Re: Re: Re: Anyone every tried a Sharpie Marker for Window Frames?
Originally Posted by blueboost
Preach on brotha!
Can I get a witness?!?! Markers are YOUR redeemer! Can I get a witness?!?!
Old 09-08-2003, 01:11 PM
freakray freakray is offline
AF Modelrater
Actually, when I read this thread YESTERDAY and decided to give it a try, there were only 5 replies in the thread, Bob Downie's being the last one at the time.
This one:
Originally Posted by phatmitsu
Thats what i use... You have to do it a few times but its black on the outside but it does have a slight purple tone on the inside.. I do about three coats.. Letting dry about 10min between coats.. Later Rick
States the opposite of what you stated, and until I replied with my thought I had not seen your post stating otherwise.
Do you see what I am saying?
You do realise that adding a coat of clear runs the risk of causing the sharpie ink to run?
AF User Guidelines
Old 09-08-2003, 01:54 PM
Lambo003's Avatar
This one:
Hi Freakray,
I get what your saying . . . Perhaps I should be reading posts a bit more carefully eh? lol
And, Oops! I should have added that I use a water-based paint for the clearcoat (specifically Polly-Scale). This minimizes the chances of the ink running. I also add the clearcoat before trimming the BMF.
There, I think that should CMA . . .
Chuck
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
have anyone every build a Cyber formula's Race car? fairladyz_gt-r Car Modeling 0 11-20-2003 08:46 AM
Anyone every go to this site? bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 15 08-22-2002 10:11 AM
