Originally Posted by 68bird
hey guys. i recently bought a 1968 firebird. it has a 400 big block with a torker 2 high rise intake and edelbrock 750 carb., a turbo 400 tranny, 383's, and flowmasters. anyways, the car does not run very good and it sounds to me like all 4 carb barrels aren't opening up. it starts up fine and idles smoothly, no knocks or anything, it just doesn't have any punch.
i'm a total newbie when it comes to engines in general. where should i start? i'm just looking for waysssss to make it run better(faster).
thanks
No bolt on's are gonna wake it up if it's not healthy to begin with. I'd start with a compression test. should be around 120-140lbs in each cyl. no drastic difference cyl to cyl. . can also do a leakdown test. if it holds air it's ok. if not see where it's leaking to. air leaking pass valves, means a valve job, pass rings, need rings, or possibly pistons too. everything checks out. do a tune up. new plugs, rotor, cap, wires, set dwell if points. set timing. about 10 degrees, with vac plugged. see if vac advance works, hook vac up watch timing see if timing advances. I'd replace that single plane Torker with a dual plane like Edelbrock RPM. I've had
good Holley's and mostly bad Holley's if they sit very long. needle and seat often stick on my 750. I replaced it with an Edelbrock Carter carb. it was great. never had to touch it. Quadrajets are good too. long as no one's messed it up.
