Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 11-29-2001, 11:31 PM
CHRIS200T CHRIS200T is offline
Send a message via AIM to CHRIS200T Send a message via Yahoo to CHRIS200T
Originally posted by poppy_morenito
How hard is it to change spark plugs ? I have never done anything like that and should I change wire too ?
Just got head and tranny work done and the car runns great while rolling but is idling funny ...
Something to check. I seen SR20's idle funny from the AAC Valve values in the ECU being way to high at idle aka Idle screw is turned in to far.. You need a Techtom or Nissans factory computer scan tool for this. Plug in to the diagnostic port and Rev the car and watch the AAC % value in the ECU sometimes when you rev it the and it decel's the car will almost want to shut off and starts to idle bad you will notice the AAC at the bottom of decel it will peg 100% and stay there and then start to drop to 90 -95 % and it can't feed enough air to the motor to idle correctly. if this happens you need to open the idle screw.. Look at your AAC % you keep opening it tell it hits about 30-35% and the cars idle should be stable again...
Chris Allen (North San Deago.)
96 200SX GTIR Powerd 497WHP on C16 351WHP on 91 oct pump gas
92 Sentra SE-R Almost stock
91 NX2000 SR20VE VVL Powered 177WHP almost stock (Girlfriends Car)
Old 11-30-2001, 03:47 PM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
Originally posted by CHRIS200T
Something to check. I seen SR20's idle funny from the AAC Valve values in the ECU being way to high at idle aka Idle screw is turned in to far.. You need a Techtom or Nissans factory computer scan tool for this..
Hey can I borrow yours ? I left mine at work next to my fluxcapicator ....lol
I guess I have too take it to the shop .... oh Andreas Miko has one .... thanks again ...
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 12-10-2001, 11:55 AM
Phish420 Phish420 is offline
Send a message via AIM to Phish420
d
Old 12-10-2001, 12:13 PM
d
Old 12-10-2001, 12:18 PM
NGK Performance Wires
(This is russdye, just changed my handle) I installed some ngk wires and everything is working good (did I fu%k up again) As for spark plug replacements I heard Trium plugs are good for a couple HP...does anyone know for sure
Old 12-10-2001, 12:52 PM
ya MR SR20 of Florda should have one with as much work as he does
Old 02-20-2002, 03:40 PM
JsL138 JsL138 is offline
Do you guys know the part #, stock heat, for NGK Iridium IXs for the G20? Thanx
