Old 05-17-2019, 12:34 AM
hypermaxed hypermaxed is offline
Re: ignition problems on 94 S10
is this the one i am looking for?
Old 05-17-2019, 01:43 AM
i stopped being lazy and went and took a pic .... this is my actual connector
Old 05-17-2019, 06:19 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Originally Posted by hypermaxed View Post
the lights on the dash and radio shut off, i do not notice any dimming of the dome or mirror lights. when i put the truck in Neutral the key won't turn at all. key won't turn unless in park. no crank at all, i turn the key to start the truck and nothing happens. before this happened i was having issues with the truck dying and stalling out so when i had issues starting the truck one day i got a CODE 54 i looked up the problems that it could entail. so i went out and got a new fuel pump relay. before i did anything i disconnected the battery. switched the relay and hooked back up the battery. that's all
this is where i got info for the code https://repairpal.com/gm-obd-code-54
It should start in neutral, as well as park. If the key won't turn at all then there is some kind of alignment issue with the shifter.
Old 05-17-2019, 06:32 AM
funny you mention that, i can turn the key in park but when i try to turn the key in netural it won't turn at all
Old 05-17-2019, 12:49 PM
Stealthee's Avatar
Then like I said you have a shifter alignment issue. Every automatic out there should start in neutral. If the key won't turn then you're not actually in neutral.
Old 05-17-2019, 01:45 PM
so i am guessing that means getting under the truck to deal with it right?
Old 05-17-2019, 03:39 PM
ok i wasn't expecting to find this when i went out to look at my truck. please tell me i just need more vacuum line and its easy to get to the spot where it connects.
Old 05-17-2019, 07:27 PM
my bro came out and tried to help me jump it again. no power is goin from battery to ignition. yes i checked fuses.
Old 05-17-2019, 07:40 PM
would the funny plastic key anti theft or whatever it is have anything to do with it not starting? if so is there a reset to that ?
Old 05-17-2019, 08:50 PM
ok i got rid of the plastic key thingy, still no start and found out on my model the NSS is on the column so i am just gonna start replacing and see if i can get it to start after that.
Old 05-18-2019, 09:31 AM
brcidd's Avatar
brcidd brcidd is offline
Is your "security" light on - on the instrument cluster? Does your OEM key have a resistor chip imbedded in it? You may have a broken security wire.
Security light should come on when ignition is switched on, they go out in about 3-5 seconds. If on continuously, or flashing, this is your issue.
Security systems (Passlock I) like yours, are often bypassed, by soldering in the proper resistor - bypassing the chip in the key.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-18-2019, 02:33 PM
i went out today with my handy dandy tester and all the wires that should start the truck are hot. the red is constant 12 the purple is 12v with key in start. i don't know if i have the screw in type if i do. i have no idea where it is. mine looks like a little white piece on top of the column and the ignition wires go to it. still frustrated but i will figure this out
Old 05-18-2019, 05:55 PM
alright i am stuck, i have taken alot of my dash apart and other stuff. can anyone tell me simply where the harness with the screw is? unless they tucked it up under the dash by the radio or further i can't see it. i have watched videos where its right there. i know what the harness should look like. if not i guess i will take everything apart piece by piece til i find it very very frustrated right now.
Old 05-18-2019, 06:35 PM
i apologize if i have got anyone mad cause i thought i knew what i was talking about. i am not a mechanic or a tech so i truly do appreciate everyone and their help. as for it not going in neutral all that was is the lil cable that goes to my indicator is getting old and not showing the right gear all the time
Old 05-19-2019, 01:05 AM
Thumbs up Re: ignition problems on 94 S10
thank you all for the suggestions and help, my friend came over and got the starter out. turns out it was bad and i was over thinking it. i will have to get a new one tomorrow. i just wanted to say this case is closed.
