| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
#16
Re: Project Evolution: 1/24 Peugeot T16 EVO 2 - Corse '86 - #5 B.Saby
I mounted the modified inlet manifold, airbox, exhaust manifold, turbocharger and bigger brakes off Tamiya's 405 T16.
#17
some more progress:
I finally made the connection bar between the inner rear wheel arches. The modified evo 2 rollcage will rest on those strut towers. Evo2 exhaust and some more engine equipment are still missing. ![]() ![]() Rear drivetrain and suspension joint with front differential, steering and suspension assembly. The front remained mainly unchanged from Evo1 to Evo2, I just added the bigger brakes that I had mentinoned before.
#18
custom exhaust and... whatever that tank is.
![]() Driver's compartment - no modifications here. Decals yet to come. ![]()
#19
Cockpit and engine bay 90% completed, however the rear half of the rollcage still needs to be changed to Evo 2.
![]() Evo2 (left side, with wrong rollcage) vs. Evo1 (my Team Gauloises build here) ![]() ![]() ![]()
#21
Thank you.
Now fabricating the rear section of the rollcage, using styrene rods and lots of superglue: ![]() ![]()
#22
Rollcage completed.
![]() The side bars then required some additional modding of the shell: ![]() ![]() It's a straight fit now. The difference to Evo1 (on the left) becomes more and more apparent.
#23
The rear wheel arches needed to be widened a bit to match the bigger wheels.
![]() ![]() Minor modifications from Evo1 to Evo2 (spot the difference...). ![]() ![]() Air intake ducting - modified from Evo1 to Evo2. ![]() ![]() ![]() Decals are a mix of Tamiya and Heller decals. The Tamiya ones are way better. ![]() ![]() ![]() ![]() Et voilą!
#24
The final stages now require some amount of scratch building and/or improvisation.
Underbody Skidplates and Diffusor I am not going to 100% replicate those, but still, for Evo2, the skidplates have to be larger. Plus, there is a whole new diffusor in the rear. Quite interesting refpic... ![]() Again, I am using parts off a Tamiya 406 T16 Grand Raid (right side) ![]() ![]() The diffuser has to be scratch built. I am using material from a pillbox. ![]() ![]() The resin diffusor also shown is from Renaissance and hereby only used as a reference. It will some day be needed in yet another 205 T16 project... ![]()
#25
I stupidly damaged the skidplate when trying to cut it to size: Some square milimeters simply broke away (see lower left).
However I was able to fix that with tape and putty. Actually I was surprised that the repair worked so well. ![]() Side windows Evo2 features large air intakes that did not exist on the Evo1. I also cut those out of the side windows off a 405 T16 GR and applied them to some clear film that once beloged to some sweets packing. ![]()
#26
Just some WIP shots (about 75% finished) to show where this is going
#27
I chose to replicate the Evo2's aerodynamic side skirts on the underbody.
A plastic spoon came in handy. ![]() ![]() ![]() Work on the rear diffusor continues, too ![]() The PE front grille needs to be much larger on the Evo2. I customized it using two Evo1 grilles (had a spare one). ![]()
#28
Really cool idea for the side skirts !
Paolo - LoveGT40 Modelworks website www.alsoldatino.com my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber FB: https://www.facebook.com/alsoldatino |
| The Following User Says Thank You to lovegt40 For This Useful Post: | ||
koooba (12-10-2016)
#29
Skidplate and diffusor almost completed.
![]() ![]() ![]() ![]() Front canard wings completed. Base was the Heller Evo2 front wing, which features correctly shaped canards, but otherwise lacks some detail. The side flaps were added from scratch. ![]() ![]()
#30
So if we look under the hood, what's actually missing by now?
Evo2 oil cooler and rear brake cooling: ![]() ![]() ![]() ![]() Still WIP: ![]() (I used a decal saying "speedline" to write something like "setrab") ![]()
