Old 11-25-2013, 02:44 PM
jzx100's Avatar
jzx100 jzx100 is offline
Re: Started to build my first 1/24 kit.. tamiya 93 Supra. Need some tips and suggestions
Now this is what the spoiler looks like.
Old 11-25-2013, 02:56 PM
jzx100's Avatar
Stock 93 Supra
Old 11-25-2013, 03:43 PM
rallymaster's Avatar
Good work so far, clean paint for a 1st 1/24 kit.
One advice I would give is to give a wash to your engine, mix 1/4 metallic shade (like bronze or dark metallic) or black paint with 3/4 water and apply it like if washing with a big brush without trying to cover surfaces, that will make details more visible.
it's a smal tip that can be simple to do and substantly change the look of parts.
Phil
Old 11-25-2013, 04:52 PM
corvettekid_7684 corvettekid_7684 is offline
Yikes! Looks like a dog chewed on it! You could probably still shape it to look ok, if not 100% exact...
Old 11-25-2013, 08:34 PM
AmbientxNoise's Avatar
AmbientxNoise AmbientxNoise is offline
Full sized plastics you could repair using a soldering iron, body filler and heavy sanding, so in the smaller scale you can use Evercoat Glazing Putty on styrene according to a couple other modelling forums. You could fill it and level all the surfaces out then use a blow dryer or carefully use a heat gun to form the spoiler back to its original shape.
Old 11-26-2013, 02:55 PM
jzx100's Avatar
Old 11-26-2013, 02:56 PM
jzx100's Avatar
Old 11-26-2013, 03:08 PM
jzx100's Avatar
LOL.. true dat..
Its not gonna be 100% for sure but I'm not gonna be satisfied with just "ok" either. I will only go with the spoiler if I can make it look right for the car, as if that's how it came with the kit.
Old 11-26-2013, 03:18 PM
jzx100's Avatar
The problem is the plastic in the middle portion of the spoiler is really thin because of its 1:24 scale. When ever I try to do something it bends and looses its original shape. So I'm thinking of putting some kind of support underneath in a way it can't be seen from any angle unless you are holding the car upside down. That's what I'm working on right now, will be posting pics soon.
Old 11-26-2013, 03:39 PM
jzx100's Avatar
Thanks. That's a great tip btw and I might try it out but what about the the decals? I've already put them on the engine cover, battery, etc.
Old 11-26-2013, 03:48 PM
jzx100's Avatar
Can anyone tell me where I can find a 1:24 hood like this one?
Thanks
Old 11-26-2013, 04:07 PM
Thanks
Exacto X-11?
Old 11-26-2013, 04:20 PM
Yes, you have to avoid passing above decals, but you should be able to wash most of the engine without touching decals.
You can also dilute Tamiya smoke (x19?) in water to make your wash paint, if so it won't cover decals like paint even if slightly passing above.
Phil
Old 11-26-2013, 04:30 PM
That hood is a Carbon Creations TD3000, which is a USDM manufacturer so that kind of limits other 1:24 Supras that would have it. It looks to be a carbon fiber OEM style with the vents cut into it and screen mesh tacked to the underside of the hood so like corvettekid said, you'll have to cut one yourself and tack scaled mesh under it.
Old 11-27-2013, 04:32 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
Your work looks good to me. I really like the sheen on the interior. It looks like leather/vinyl coated with armor-all (which I would not recommend on a 1;1 car since its too greasy).
Another day on the job!
