Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 02-08-2014, 11:20 AM
pvisser pvisser is offline
Send a message via MSN to pvisser
Re: Air Ride
Checked resistance of exhaust solenoid. And get 17.4 ohms.
Old 02-08-2014, 02:49 PM
Tech II Tech II is offline
Re: Air Ride
When you disconnect the level sensor, and jumper "A" white to "C" black, the click you hear is the solenoid clicking, not a relay.......since you don't hear a corresponding hiss with the release of air, it looks like the solenoid is not working.......the reason why you don't hear a "click" when you reconnect the harness, right away, is because the level sensor has a built in delay function, that buffers the signal...if it didn't have this, with every movement of the vehicle, the ex solenoid and compressor would be constantly working, against each other....
Old 02-08-2014, 04:42 PM
Ok. Took the compressor out.
Took a reading of just the wires going to the solenoid on the compressor, and it is stuck open. (ie the ohm meter was not able to get a reading).
Based on all the info you and this forum have provided me, I've ordered a new compressor.
Too bad, I actually took the solenoid out with some work. But putting a new one in looked to be fairly simple.
While I had the solenoid out I tested it again with the meter. It's definitely dead.
Paul
Old 02-08-2014, 04:45 PM
I had checked the wrong solenoid in this step. I had measured the resistance of the solenoid inside the van for tire inflation. My bad.
I'm also thinking I was tripping that solenoid, since a bench test with a 12 volt battery on the compressor solenoid did nothing.
Paul
Old 02-09-2014, 07:09 AM
Re: Air Ride
Yeah, have seen those exhaust solenoids fail......like I said, unfortunately, they are integral to the compressor and not replaceable.......you'd think they would be.....
Old 02-10-2014, 07:52 AM
Yeah.. You'd think.
Paul
Old 02-26-2014, 07:09 AM
Just wanted to say thanks for all the help and assistance.
Installed a new compressor assembly, and we are working great again.
Paul
Old 02-26-2014, 07:53 AM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: Air Ride
Glad you figured it out. Is the part serviceable, or did you get one from a donor?
So that's what the compressor looks like inside. Not a lot to it really.
Was curious to know, but mine is '99 vintage and a lot more corrosion on the brackets and bolts that hold it on. If it falls off, I'll do an inside look like you have done. Thank for sharing.
Oh and hey, your bench looks a lot like mine. Are you right or left handed? Just asking. I'm a lefty.
If I had my way, every GM car I ever owned would be a Chrysler!!!
Old 02-26-2014, 09:59 AM
The solenoid is serviceable on this pump. As you can see here:
It is externally removable.
FYI. I'm right handed, and the brackets etc only look so good cause I painted them.
Paul
