#16
Re: 1999 cooling fan will not operate
Coolant fans won't come on with a/c UNLESS there is 175 psi a/c pressure generated (On GM W-cars as is yours) So does your a/c work? Is It capable of 175 psi head oressure?
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
#17
compressor dosent engage.... |
#18
When I pull the sensor connector both fans WORK....when i reconnect, they stop....
#19
If you are facing the fuse block. The fat green wire is left front. the thin dark green one is to the right front do you have a diagram?? |
#20
If the fans work sensor disconnected the circuits are all good, the pcm does this as a default to prevent overheating when it cannot read engine temp. So now get a scanner on it and watch the temps, as they approach 222, the fans should come on, reconnect sensor of course.
| The Following User Says Thank You to maxwedge For This Useful Post: | ||
djjm3 (11-23-2012)
#21
| Tags |
| carlo , chevy , cooling , fans , monte |
