| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | ||
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: 1996 Lumina 3.1 fuel filter
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#17 | ||
As I said, the harness is a common but not predictable issue. My truck was JUST STARTING to melt the power wire to the pump, and it's got 300,000 miles on it (I put 125,000+ on it, I don't know the service history prior to 170K)
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
#18 | |
Here's a trick I learned while dropping a gas tank by myself. The two hoses that lead into the back of the tank, one the filler tube and one I guess the overflow tube, are very hard to get off. One, the filler tube, looks like a radiator hose, and the other is smaller. They are nearly impossible to get your hands around to twist free once the clamps are loose, and of course you are blocked trying to move the tank forward so they can slide off. I was afraid to just let the tank drop and hope they popped off for fear that they'd actually break off the tank with the connections still intact. Those things were DIRTY and were very stuck. Here's what I did: I took an old Buffalo screwdriver with a thin blade and bent it 90 degrees about an inch from the tip. (I'm sure they make a tool for this but I didn't have one) I had just enough room to get the tip between the hoses and the tank connection and break them loose at least an inch in. I slowly lowered the tank, a little at a time, then returned to the back of the tank and kept pulling on the tubes every time I did it. The large one came right off as I lowered the tank, but the smaller one was very long and very stuck and wouldn't slide off. I was also thinking of the job I was going to have lining up both of these tubes, in addition to the two vacuum lines on top of the tank, while still lifting and securing the tank on re-installion. There is a hole in the cross member of the rear suspension where the smaller tube is exposed pretty well. I reached up through there with large cutters and snapped it in half and the tank was free after a couple more lowerings and some more pulling on the filler tube. Once I got the tank past the exhaust this was easier, as I could also move it slightly side to side. When I went to put the tank back in, I put a new piece of line on. (with a clamp, which it didn't have, and I was also afraid it would fall off while I was putting it in) I left the line deliberately long, so when I put the tank back in all I had to do was stick it through its space and let it hang. Once I got all the other tank lines reattached and bolted the tank back up, I went to the back, lined that smaller piece up with the metal piece it connects to, cut it to the length I needed and clamped it. There might be an easier way to do it yourself, but I couldn't figure it out and thought I'd share this. Thanks for all your help!
