Old 08-01-2012, 10:05 AM
1990Cavz24 1990Cavz24 is offline
Re: '89 Cavalier 2.8L Z24 won't accelerate over 25mph, car just jerks.
Yeah I figured it was a long shot. I still think it sounds CPU although my initial feeling was fuel pressure until I read the post where the fuel pressure tested fine (including dead heading the pump by shutting the vaccuum off to the regulator). Only thing I note is that the readings were not given. If someone was going on the TBI #'s (15-20psi) instead of the MPFI #'s (35-40 regular running and upwards of 60 under full pressure) that may be where the error lies. Wonder what the readings obtained were.
Old 08-03-2012, 04:50 PM
pappyl pappyl is offline
Will need to hook it up to a scanner and monitor what's going on.
I would suspect the TPS (throttle position sensor).
What could be causing this...
1) insufficient fuel pressure (pump not keeping up, bad regulator)
2) timing not advancing properly (bad ignition control module)
3) Computer thinks everything ok
- bad prom
- bad sensors (like TPS) flatline and lie to computer
- maybe a physical interference on throttle
If timing chain skipped a tooth it should be idling like a dog.
Old 08-03-2012, 05:51 PM
matthew24u matthew24u is offline
the compression could all be 50 psi it would still rev up and accelerate you don`t have a compression problem. I would get a scantool & look at injector pulse with sounds like your not getting fuel delivery to the engine. should be TBI if so you can look in the TB and rev it up under the hood and see your fuel spray just dumping everywhere at WOT. IF you can`t then you have got injector or PCM problem. signed, always stuck in diagnostics!
Old 08-03-2012, 11:45 PM
Joe W Joe W is offline
This does seem to be a possible VSS issue, although I must question why a code has not been set, the same reguarding the CPU, even through failure they throw a code. Have you tested the VSS?
1999 Cavalier 2.4 Z24 Strange Issues JaseVaughn Cavalier Problem Diagnosis 4 03-26-2010 10:51 AM
Can anyone tell me where i can find performance parts for a '89 Cavalier 2.0L 4cyl?? Vejita88 Performance 3 01-13-2007 09:38 PM
vertical doors for '89 cavalier 2-door? cavydriver Cavalier 3 09-14-2005 12:15 PM
88 z24 cavalier 2.8L blown head gasket pls help ... coocoo44 Cavalier 10 10-13-2004 05:47 PM
93 S-10, 2.8L, 5spd WON'T START NOW!! HELP PLEASE!!!!! trahanphd S-10 3 01-02-2004 10:12 AM
Tags
acceleration , cavalier , chevy , engine , stalls
