Old 11-09-2001, 07:32 PM
Rich's Avatar
Rich Rich is offline
Never Fear, Rich is here!
Send a message via MSN to Rich
Originally posted by kbslacker
I dont see how it could. The threads are covered by the lugnut. As long as you do it straight, it should unscrew evenly.
I was thinking that was how a locking-lug worked. I thought that it had teeth or something that went against the threads on the stud, making it impossible to turn, unless u have the key to release the teeth
Thats why I was thinking that if you forced it, the lock on the lug would screw up the threads on the stud, making an even bigger fuckpot.
My Wheels
15' Kia Soul SX 2.0L
13' GMC 1500 P/U 5.3L
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I thought those locking nuts would strip the threads if you tried to force it like that. Hence the purpose of having it so the wheel cant be removed. But, I am not 100% positive of that.
Resistance Is Futile (If < 1ohm)
Old 11-09-2001, 07:43 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Well, mine are a regular nut, that looks like this on the end:
You just need the socket that fits in that. Other than that, its a regular nut on the inside.
Old 11-09-2001, 07:48 PM
Rich's Avatar
Oh ok. There must be different kinds I guess, cause the ones Ive seen use a regular lug-wrench AFTER you losen a small, custom shaped side screw, to take the pin away from the threads on the stud.
Johnny. If yours looks like KB's, then id say give the vice grips a try. And Good Luck
My Wheels
Old 11-09-2001, 08:53 PM
YogsVR4's Avatar
That is different then my Mitsubishi's. Yes, I'd have to agree with KB. Give his plan a shot if you have that setup.
Old 11-09-2001, 09:54 PM
olds88's Avatar
olds88 olds88 is offline
you guys might laugh at this but this is how i do it at the dealer
1 get breaker bar, BFH (big fucking hammer) and a asortment of 12 point 1/2 drive sockets
2 beat the socket onto the wheel lock, pick the socket that is just undersized
3 use the breaker bar on the socket and remove the lock
and trust me this works better than those bs specal tools the companys offer
what is the world coming to???
Old 11-10-2001, 12:29 AM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
If they are factory installed, your local dealership should have an entire kit of wheel lock keys to get it off with.
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 11-10-2001, 02:08 AM
johnny's Avatar
johnny johnny is offline
Send a message via ICQ to johnny Send a message via AIM to johnny
yep mine look sorta like the lugs that were posted. Except that the pattern at the top of it is a 5-point star. So what do I have to do now?
Old 11-10-2001, 11:47 AM
Rich's Avatar
Grab the vice grips, hook em on real tight, and try to crank it off.
My Wheels
Old 11-10-2001, 04:15 PM
MercCougarXR7's Avatar
MercCougarXR7 MercCougarXR7 is offline
When I had a flat - I was in the middle of nowhere. I looked for my 'key', and when I couldn't find it anywhere in the car, I was pissed. I had to walk to a farmers house, and call for a ride home.
Anyways, I took back with me some chisels, a BFH, and went crazy on the lock. I mangled the stud I guess, and couldn't even put another one on.
So I took it to the Ford dealer, and they had some spare 'keys'. I had them remove the other 3 lugs, and replace them with normal lugs. They also had to remove my brake to get at replacing the stud that I screwed up. Total bill - $80 to change a friggen' stud !!! Talk about expensive for not having a 'key', eh?
Anyhow. Your dealer will have keys if they are a stock locking set. But using a vise grip or socket will be your best bet to removing the little bastard. Then you won't have to replace any stud either! Depending on your area, consider getting rid of your locking key set - they are nothing but a pain in the ass around here. Wheel theft is not an issue, even for guys with pricey wheels. And if theives really wanted your wheels, they'd use a socket or vise grip to remove the lugs !
Good Luck,
Kevin.
2000 LS8 Sport, 1992 XR7 5.0 HO
Help Help Help!!!!! Need Help! shahram177 Off-Topic 12 11-09-2004 07:22 AM
95 firebird help help help tranny help chevyls7 Camaro Discussions 2 08-28-2004 11:09 PM
help me help me help me please fuel pump help my90horsy Mustang Talk 16 12-05-2003 09:38 AM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
