Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-05-2011, 02:06 AM
thusted thusted is offline
Re: 1999 chevy malibu fuel filter disconnect broke?
I had the same problem when replacing my gas tank.
Here's what I did.
I cut a section from a ball point pen casing, cut a slit down one side and forced it open and fit it over the fuel line. Then I slid the casing into the quick release joint and it spread the tines enough to release the connector.
I make it sound easy, but I did this after hours of trial and error to get it off.
Hope it helps.
Todd
97 malibu v6 137k
Old 05-05-2011, 04:53 AM
chevy_malibu chevy_malibu is offline
Thanks so much. I gave up and tested fuel pump relay and bingo.
Old 07-15-2014, 10:43 PM
car_curious car_curious is offline
here is a tip that wish i would of known prior, the black quick connect fitting (with the tabs, i dont mean the green one) wasnt needed when replacing the fuel fitler because the new filter has the white clips for a secure connection, asIt could of saved me self alot of frustration and hours. we spent hours trying to separate it from the fuel filter witout breaking it so if it breaks THATS OKAY!!!! you dont need it, the male end of the new filter wont fit into the black not so quick connect. so follow usual way to separate the two, squeeze with a pair of needle nose pliers and pull filter out, force it if you have to but be cautious of fuel line of couse and if plastic breaks make sure no pieces are left in the line, the should be the black fitting and a metal ring. heres two pictures showing that the old fuel filter doesnt have the white clips like the new one. hope this helps.
strange heating problem with 1999 chevy malibu saraliesel Engineering/ Technical 7 03-25-2011 08:15 AM
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 02:08 PM
1999 Chevy Prizm - lock rod clip? n1ckml007 Prism 1 12-21-2010 10:41 AM
1999 Chevy Prizm - defogger switch light bulb ( LED replacement) n1ckml007 Prism 0 11-09-2010 10:26 PM
1999 chevy malibu bad fuel pump petecoach007 Malibu 4 03-13-2009 01:37 PM
