Old 07-01-2013, 04:05 PM
j cAT j cAT is offline
Re: 97 siverado a/c problems
Originally Posted by chrschrsz View Post
Thank you very much for the information, could you please let me know where the resistor block is, thanks again.
remove the blower motor,check the connector/wires to it. look inside the duct for the resistors. with this model the blower motor not running is the motor is defective. use a jumper wire[s] and see if you can get it to run.......
The Following User Says Thank You to j cAT For This Useful Post:
chrschrsz (07-11-2013)
  #17
Old 07-05-2013, 01:52 PM
chrschrsz chrschrsz is offline
Originally Posted by brcidd View Post
If blower motor is inop- check connector plug- it is under dash passenger side- if connection is okay- verify voltage- if voltage okay- replace blower motor after bench check.
The blower motor is blowing only out of the defroster, do you have any suggestions, still no cold AC. Please let me know if there is somewhere else to check. Thanks for all your help.
Old 07-05-2013, 05:15 PM
brcidd's Avatar
brcidd brcidd is offline
Most likely , your defroster mode door arm is dangling from actuator above gas pedal- from popping off it's axle (door) - look right above gas pedal- and put it back in place-and add some locktight if in doubt- go look at your neighbor's 94-98 GM truck..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
  #19
Old 07-11-2013, 12:09 PM
Thank you very much for the information and have a good day...CHris
Old 08-19-2013, 04:49 PM
Thank you very much, sorry for the late response, been on travel, but thanks again...CHris
Old 12-13-2013, 01:41 PM
I have a question about a heater core, I had my truck parked outside and did not use it for a while, when I got inside to start it up, there was water moisture on the inside of my windshield. Is that a sign that my heater core is out?
Old 12-14-2013, 03:32 PM
the mositure issue may be a leaking windshield, also the air box ac drain may be plugged holding water inside of it.
Old 12-16-2013, 05:28 PM
Is there a way to drain the extra moisture out of the ac box? If so please let me know, thank you.
Old 12-16-2013, 05:55 PM
in the fire wall area passenger side there is a drain tube to drain the water . not easy to see . when you find it get a soft rubber hose 1/4 or 3/8 dia and stick in hole to loosen up any debris which you most likely have being this old .
Old 01-23-2014, 06:38 PM
I need to know how to replace the ac controller underneath the radio on a 1997 Silverado 4x4. Can anyone help me with this problem? Thank you...Chris
Old 01-23-2014, 08:35 PM
777stickman 777stickman is offline
The instrument panel cover needs to come off. It is a snap-in panel. Start at the top of the dash and work it out. Steering column needs to be in the full down position (if you don't have a tilt column, you may have to drop the column manually) and gear selector needs to be in the full down position (1st gear). Once that's done you will have to reach up behind the controller to release the holding tabs to remove it.
Hope this helps.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
chrschrsz (02-19-2014)
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 11:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 06:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 09:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 08:38 AM
