Old 02-24-2011, 09:05 AM
Didymus Didymus is offline
Re: Urethane question...
I forgot to mention thinner. The "right stuff" is low-temp reducer. FinishMasters sold me BASF R-M UR40 specifically for the 2K clear, and it also works great with the PPG and Omni 1K basecoat I use for color coats. The reducer is available in quart cans.
I tried using ordinary lacquer thinner with the basecoat. It worked okay a few times, and then it caused a batch of paint to curdle, so now I always use the reducer.
By the way, the term "basecoat" is commonly used in 1:1 automotive painting. It sounds like it might refer to primer, but it definitely does not. It means color coat.
D D M S
Old 02-24-2011, 09:17 AM
stevenoble's Avatar
Originally Posted by Zonic2001 View Post
an estimation of how much thinner should I start with my trial and error spraying. If you don't want to post in here at least please PM me. Your help is greatly appreciated.
You will have no problem spraying through a good airbrush with a 0.5mm tip. I use a Tamiya HG Wide trigger type and this sprays it very nicely. As for the thinning ratio, start with the recommended one from Hiroboy's site 50ml clear, 25ml of hardener and 15ml of thinner. This makes a lot of clear though, so keep the ratio the same but use smaller amounts, or you will waste a lot of product. Remember only mix what you will use because once it goes off it is useless. General rule is whatever the quantity of clear you put in, you need half the amount of hardener. My usual small mix is 10ml clear, 5 ml hardener and 3-4ml of thinner. Sounds like a lot of thinner but it sprays really well for me by using that amount.
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
Zonic2001 (02-25-2011)
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
front urethane bushing question zimaad Aurora 0 06-16-2004 01:20 PM
Question about Urethane Front Bumpers? Masta '88 - '91 Civic | CRX | Wagon | Shuttlee 2 01-28-2004 06:34 PM
