Old 07-26-2010, 05:10 PM   #16
MidMazar
MidMazar's Avatar
Re: Novitec Rosso Ferrari 599
I like the progress.
In Progress
Old 07-26-2010, 07:20 PM   #17
luchoteam
luchoteam's Avatar
Excelent work you are doing!
Keep posting
luchoteam is offline   Reply With Quote
Old 07-26-2010, 10:18 PM   #18
agamo
agamo's Avatar
Send a message via ICQ to agamo Send a message via MSN to agamo Send a message via Skype™ to agamo
Great work on the seats! I liked the method! thanks!
Happy modeling!
Ramon Garcia
Puebla, Mexico
agamo is offline   Reply With Quote
Old 07-26-2010, 11:16 PM   #19
Entau
Entau's Avatar
thanks again
i realise i wont be able to paint the button nicely
so i remove it
scratch built it with 0.3mm styrene, kotobukiya parts & top studio round hex again
not perfect but better than if i would hand paint it
Entau is offline   Reply With Quote
Old 07-27-2010, 06:51 AM   #20
Tompidom
Tompidom's Avatar
Woo that is pretty awsome!
Check out my Youtube Channel for Video's of my builds and some tips and tricks
http://www.youtube.com/user/xrcflash
https://www.facebook.com/thescalemodelingchannel
My online webshop
www.thescalemodeler.com
Tompidom is offline   Reply With Quote
Old 07-27-2010, 12:07 PM   #21
TRBJ
Send a message via MSN to TRBJ Send a message via Skype™ to TRBJ
very heuge WOW for your interior work man... everythings just wow...
sylvia
TRBJ is offline   Reply With Quote
Old 08-03-2010, 12:00 AM   #22
Entau
Entau's Avatar
Tompidom & TRBJ thanks
Some progress on the interior, decided to cut out the centre console as detailing will be much easier & i want it to sit on top of the flocking. But it takes me 1 hour & 15 minutes, i thought can be done in 30min, maybe i wasn't using the right tool
then trace the shape with masking tape, transfer to a 0.3mm plastic card, cut and paste on top
cut away the plastic excess with knife then sand away with files
in total it took me 3 hours plus for the whole process
also drill the speaker holes and add PE, notice the speaker is level with the surface instead just glue on top of it, just adapt Ramon's WIP
both seat prime to check for any flaws, still require minor touch up
and prime interior to check for any flaws, there is few, so still need touch up, not yet added is the speaker & air-cond vent PE
Old 08-03-2010, 11:58 PM   #23
Entau
Entau's Avatar
Cut off the air-cond vent cover, initially thought to just separate it...
but the cover flies over my room, can't find it
no choice but to find replacement, the Wave parts look similar, 4mm but slightly taller, so i just need to sand it down
the cover should be on top of the pe
luckily it fit
i think it's better to paint it first before i glue the PE, so i spray silver, masked then spray matte black mix with a bit of grey
glue it using CA glue
and this is how it looks
store in container, if not sure gone...
Old 08-04-2010, 02:47 AM   #24
Robi J
Robi J's Avatar
I like your approach to the kit. There are also some interesting suggestions, thanks.
Very clean as well.
R
Robi J is offline   Reply With Quote
Old 08-04-2010, 06:01 PM   #25
MidMazar
MidMazar's Avatar
Ive been using a container like that also, makes life a lot easier. The interior looks really good. Vents are topnotch!
In Progress
Old 08-05-2010, 02:57 AM   #26
Entau
Entau's Avatar
Robi & Midmazar, thanks
Updates:
First i trace out the speaker's grill shape on the dashboard, drill out holes and bevel the shape so that the grill flush with the dashboard.
Using stretch sprue, i apply CA glue from behind
dashboard prime
Scratch built window button from tamiya round rod, paint it silver
Cut out some left over black decal, faster than spray black mask then spray silver
Old 08-06-2010, 01:17 AM   #27
Entau
Entau's Avatar
last night i tested the 1/48 scale motorsport carbon fibre on mr color steel base
honestly not very visible if look more than 40cm away
only visible on close up
then i gloss coat & compound it, not supposed to do this, as the decal not 100% dried & the clear coat haven't cured completedly, it's just for testing
the scale looks ok to me, just now i'm headache how to apply the CF nicely, glosscoat, masked and spray the rest semi-gloss without any problems
look quite close compare to my reference
Old 08-06-2010, 05:40 AM   #28
Tompidom
Tompidom's Avatar
Youl work it out
My online webshop
Old 08-06-2010, 06:25 AM   #29
Robi J
Robi J's Avatar
I would go deliberately spraying the whole dashboard with Mr. color steel base, making templates for the vents protuberances and the remaining area to be carbonized. Then decaling (the color underneath should forgive small imperfection), clearcoat and polishing. If dash panel lines are deep enough, neat masking of the carbonized area should not be so difficult… then final shot of semi-gloss or matt black.
But you’re for sure skilled to obtain a clean result, even without my suggestion
However, charming progress.
R
Old 08-06-2010, 08:22 AM   #30
gionc
Authorized Vendor
gionc's Avatar
Seats are SUPERB!
gio
