Old 06-21-2010, 10:29 PM
j cAT j cAT is offline
Re: busting flywheels
Originally Posted by mudrunner80 View Post
I did use thread lock last time. Not sure what happened. I checked the crank shaft and there was no play. I'm hoping I figured it out. I will keep my eye on this one and keep you posted. Thanks a bunch guys!!!
Don
what can happen is the threaded holes have oil and other contamination messing up the locker...use a spray can of solvent / electric contact cleaner with a spray straw to clean out the holes ..even use a small wire pipe fitting brush to clean out the rust/debris ..
Old 06-22-2010, 09:00 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As in post 2 always check engine dial pins for missing and wear and pushed off center. And transmission dial pin holes for wear.
Also converter pads fit to flywheel.
On the engine mounting bolts double check for torque and tightness.
I always use a breaker bar or long 3/8 ratchet to tighten them.
Get them good and tight.
But stop before you twist them off.
And make sure no engine vibration or drive shaft vibration when driving down the road.
Any vibration will loosen up engine mounting bolts.
Good Luck
MT
