Old 05-05-2003, 12:53 PM
911GT2 911GT2 is offline
Originally posted by civicHBsi91
u must not know much about hondas, and dude not to insult you but i would learn alittle more about cars before you go and get behind something that pushes 180 hp
Aside from a GSR/Type R or a Prelude, both of which are disgustingly overpriced (partly from demand, partly from a high initial price) no stocker will push 180hp without forced induction.
And Civics don't respond very well to forced induction. It's a well built engine, just not overbuilt enough for a turbo or a supercharger to make it as reliable as a DSM for example. Just gotta replace second gear, that's all.
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 05-05-2003, 12:56 PM
CAptynCrunch CAptynCrunch is offline
Alex, I'll take the del sol and the civic SiR both with the B16 for two hundred please.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 05-05-2003, 02:48 PM
Both of which are ungodly overpriced.
Old 05-20-2003, 10:02 AM
DblOvrhedCamron's Avatar
DblOvrhedCamron DblOvrhedCamron is offline
Send a message via AIM to DblOvrhedCamron Send a message via Yahoo to DblOvrhedCamron
Since when are GSR's overpriced???? ITs b/c there superiorly built automotives.
On the contrary most civic's come stock with reinforced ductile cylinder walls, due to the fact that they use a higher CR than most auto's. You can slap a turbo on a GSR and have it pushing well over 200 hp using 6 lbs of boost and no internal work. I don't know where your getting this 2nd gear replacement crap (the car takes way more work than that) and there reliability is awful. From speratic spool to manifold problems those things take a shit fast, don't believe me do some research the most reliable cars in the world arent Mitsubishi's. I'll give you a hint to who are though, it begins with an H and ends with an A.
fast asleep....
Old 05-20-2003, 11:58 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
word :o
for wut u get outta a gsr/type r/lude it isn't over-priced at all. 8k (not the type r/lude, commenting on the gsr) for a car that will run low 15's outta the box an run w/ the best of them in auto crossing (w/ a capable driver that is), an that u'll be able to put over 200k miles on. o...add some leather seats, nice styling an all the other normal comforts of a nice ride, an ur lookin at a GOOD deal. i jus don't see the basis for ur comments 911GT2. yes, the prices are driven up a bit because of the demand, but since when is that a bad thing? in the large scale of cars, 8k is NOTHING.
o...an one last thing, the Del Sol VTEC is a quick little car that will only run u around 5-6k IF u can find one...keep that in mind also (since u can push it to 180 w/ out FI)
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-20-2003, 05:32 PM
The 4G63 motor is extremelt overbuilt and there are no known problems with it. Their AWD system is also very good, no known problems. The second gear syncho is known to go out and make you grind second gear to dogshit. That is their only known problem. Yes, they take more maintenance, but that's worth it if you want power.
If you can tell me what a ductile cylinder wall is I'll give you a million dollars. Seemingly just another case of DOHC spouting off false information. I think you're talking about "sporadic spool" and all that means is that when you overboost the engine, it may spool too fast and put way too much boost into the engine. With a boost controller and a downpipe/wastegate those problems are gone. And those problems only occur when you shove a huge turbo onto it, never with the stock T25. And "manifold problems" is generic rhetoric. Show proof.
Hondas are reliable, but they have the one enemy of forced induction: high CR. The high revs don't always respond well to turbocharging either.
Old 05-20-2003, 07:29 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I don't think Hondas suck. I just think that to get 180hp out of a stock Civic (barring anything short of a JDM B18C transplant) you'll need forced induction. And Hondas generally don't respond well on the reliability front to forced induction.
Don't accuse me of not knowing my shit too
And if you buy a car solely to do an engine swap, why not just buy the car the engine was swapped out of???
Because it would not be as fast. Images having a GSR and then imagen having a GSR in a cx hatchback. The cx hatchback would kick the GSR's ass. and handle better. Thank you I said my peace. You don't even need a 180 horses to be fast. MY friends N/A D16 sohc ran a 12.8 with 151 horses to the wheels.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-23-2003, 06:32 AM
its an iron ductile sleave jackass, in this case its part of the cylinder wall. I was reffering to sporadic spool is when the turbo spools whenever the hell it wants too. "sporadic- Occurring at irregular intervals; having no pattern or order in time."
I take it from your response you've never worked with a mitsubishi.
You say you own a honda yet I don't believe you, you badmouth them way to much to have ever owned one. Where you live honda's must cost as much as a skyline to mod, I'm never going to canada. A civic might set me back 90 g's.
fast asleep....
Old 05-23-2003, 10:50 AM
dreemkill dreemkill is offline
Send a message via ICQ to dreemkill Send a message via AIM to dreemkill Send a message via Yahoo to dreemkill
and i shall 3rd.
I'm gonna second this motion.
Originally posted by fakirone
.... Nos this, nos that, my 10 second nossy nos will nos your nos.
Originally posted by Prelussion
And then both of you guys w/ you sewing maching powered cars get passed by a moped w/ a 5hp Engine and he goes on to put 5 car lengths on you. Racing an EX vs a DX is like a 10 speed bike vs a golden retriever.
AF Upstate Crew -- Member #1
Current Audio: none. car dead.
Old 05-23-2003, 06:38 PM
I'll take a pic if you want. But it's just a stock 2001 LX sedan. Big deal eh?
